Question about Radio Communications
Was receving transmission from a local cb buddy,
Was recieving transmission from a local cb buddy, on channel 24 but he was transmitting on 22 i could transmit on 22 but would have to go to 24 to here him 5 mins later problem gone.
Shuttle83
  • 1139 Answers
SOURCE: cb transmitting problem
Hello kaelea,
Check your ground wire and by your post I gather that you are user some form of headphone device, I say this because normally the speaker is off when the microphone is keyed. I would also check the controls on the headset if you are using one.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 16, 2007
wyoed1
  • 211 Answers
SOURCE: cb radio
Some CB Radios require the mic works right or the receive won't work. Also it could be a detector diode bad. I have also found cold solder joints ( broken lead from the PC Board ) around the if sections. You might take alook with a magnifing glass and see if you can see any bad joints. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
Benimur
  • 6966 Answers
SOURCE: my galaxy 959 cb radio wil not put out any transmit
Based on your post of no transmit, a couple of possibilities:
1. defective microphone or cord or PTT switch (the red TX light does not come on when pressed);
2. TX light comes on but no output, defective finals and/or drivers. These are the transistors screwed to the chassis of the radio very near the antenna terminal;
3. defective regulator IC that provides the TX B+;
5. insufficient amperage from you power supply;
6. too high SWR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 16, 2008
scramblepad
  • 66 Answers
SOURCE: transmission with hand held cb radios
We don't know what kind, model , etc. but it sounds like the driver is fine and you blew the final transistor which is about 2 to 5 dollars plus any service charge if you have some one do this for you. It is simple if you know solidering and electronics. First we need to know the model number and then hunt for a schematic.
Hope we can help you more.
Kevin
Posted on Mar 27, 2008
  • 141 Answers
SOURCE: not able to transmit or recieve on cb radio in car
Its a broken connection in the antenna coax :(
Posted on Jan 30, 2010
No transmit or recieve
sounds like a repair for a tech to me.
Jan 16, 2014 | Galaxy Radios SSB Echo Base Station CB...
Will not transmit but will recieve
you may have a broken transmit wire in your mic get a mic tester and check it out. If its not the mic then its an internal problem
Aug 06, 2013 | Midland Radio 77-160 XLT 40 Channel ROAD...
Realistic trc 443 cb quits transmitting and recieving
Sounds like the weather alert system is getting activated.
Jul 26, 2010 | Uniden PC78ELITE 40-Channels Base CB Radio
Talkabout T5800 (22 Channels) 2-Way Radio: droped in water will not transmit but will receved...
Depending on the type of microphone used, if not the type using the speaker as a microphone, it may be damaged. I would though, suggest you remove the battery, open the case and allow the innards to dry in a warm place for several days. Even daily exposure to the sun should work fine.
May 16, 2010 | Motorola Talkabout T5800 (22 Channels)...
No audio transmit or recieve adio chip 1A7217AP IC
it may not be that IC but maybe a electritic cap or a transister.
Jul 30, 2009 | Cobra 18 WX ST 40-Channels Base CB Radio
Midland squealing when talking
soundwas keying up at the same time.s like it could be one of two problems. a loose wire in the mic or some one near you keyed up the same time as you. if the wire in the mic is loose sodder it. If some one keyed up near you you might have blown the reciever chip.
Sep 15, 2008 | Midland 1001Z 40-Channels Base CB Radio
Cant transmit out
Not really enough info to help you, but you MUST check the SWR of your antenna system. I've seen many cases where the antenna studs were incorrectly installed, shorting the antennas to ground. Also, make sure the Dynamike control on the CB radio is turned fully clockwise.
Aug 23, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
I can recieve but i cannot transmit
sounds like you might have a bad voltage regulator
Apr 03, 2008 | Uniden Bearcat Pro PC68LTW 40-Channels...
Cb radio
Ed
NC Electronic
Mills, Wyoming
Dec 02, 2007 | Galaxy Radios DX-33HML 40-Channels Base CB...
Radio Communications Logo
26 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
