Question about Cycling
Cleats regularly coming out of the pedals? - Cycling
Have bought a rebuild kit thanks
Posted on Jun 30, 2009
Shimano Clip-on pedal's tension
Check for wear on your cleats and the pedal. Normally, the cleats wear down to the point that they get loose. Rarely does the pedal wear to that point unless damaged or very old.
Jun 26, 2017 | Shimano PD-A530
Is there a way to adjust the PD-6401 pedal? I'm
There's only one screw on the pedal. THAT is the tension adjustment. One way tightens the release tension, the other way loosens it. Also spray some lube on the cleats and the moving pedal surface that touches the cleats.
Jul 29, 2011 | Cycling
How do i fit cleats to shoes. holes don 't match up?
All SPD pedals use a 2-hole side-by-side mounting pattern. Your shoes must have this same pattern or this is no way to mount the cleats.
Look at the bottom of your shoes:
Is there a 3 hole pattern in the shape of a triangle? Then this is a Road shoe, it may or may not have the 2 hole option. If it has the 2-hole option then you will see generally one fixed hole and a long slot next too it. If there is no threaded insert then one has too be added. Some road shoes that are capable of having the 2-hole option need an internal adapter.
If you have mountain bike shoes (shoes that the cleat once installed is recessed), then you should see two side by side holes. Again some shoes need an internal adapter to provide the threading to screw into. These should have come with your shoes. If you don't see any holes, then you may have a cover that needs removing to gain access.
If neither of these is your scenario then you should consider visiting a bike shop to have them look at your shoes and see what the exact problem is. Any half-way decent mechanic or shop person could tell you in a couple seconds if the shoes and pedals are compatible.
Nov 26, 2010 | Shimano Pda520 Spd Clipless Pedals Bike...
I've stated playing baseball a few months ago. Normal running shoes are not comfortable. Looking for a good shoe - any thoughts guys?
If you are going to play baseball, regular shoes won't suffice. Baseball cleats are specially made for baseball and are required on most levels of league play. Here are some instuctions on how to choose the best shoe for you:
1.Find out what type of cleats are allowed in your baseball leagues.
2.Locate a store in your area that specializes in baseball apparel. Use your phone book and look under the baseball listing to find specialty baseball stores.
3.Try on the baseball cleats at a local store. Baseball cleats are different than other types of shoes, and the sizes might not correspond exactly to your regular shoe size.
4.Shop around for prices once you have found the right pair of cleats for you. You can look in different shoe stores to locate the lowest price, as well as look at online baseball apparel shops.
Oct 27, 2010 | Clothing Accessories
Can't fit the cleats to MO76 shoes. Instruction
assuming your using Shimano pedal cleats?
You should have on the bottom of the shoe 4 threaded holes showing.
(if not then you will need to check the shoe box as sometimes they need to be fitted)
The cleat should be placed directly on top of this... with the point facing towards the front of the shoe.
You then need to place the OO plate on top of the cleat and place the crews in making sure the cleat is positioned straight.
Once tightened then place the cleat on the pedal and make sure its position is correct and your shoe is sitting straight then re-tighten.
hope this helps.
p.s. try here http://drivemybike.wordpress.com/2009/05/23/understanding-clipless-pedals-installing-cleats-on-shoes/
Feb 26, 2010 | Shimano Cycling
One shoe won't snap into spd pedal
SPD hold on to cleats with a spring loaded action. This is normally adjusted with an allen key. Check that this is not screwed in so tight that action is locked up. If you don't have adjustment instructions go to shimano.com and download. You should be able to check for movement by pushing against spring clip with screwdriver (saves the fingers but mind it doesn't slip). If no movement also check for foreign body in pivot of clip. If all OK check for position of cleat in shoe. Make sure mount position is same as other shoe.
Dec 06, 2009 | Shimano M520 Spd Pedals
I just bought a bike with Look Keo Classic pedals 2009. The bike shop sold me a pair of cleats to fit on my Vittoria shoes.When I mount the bike and clip on to the pedals I find that my foot moves left and...
The red cleats have 9 degrees of float and the grey cleats have 4.5 degees. What you describe is normal and you soon get used to it and I really like these pedals.
Sep 03, 2009 | Cycling
Fit pds cleats bike pedals
This site has the info:http://www.parktool.com/repair/readhowto.asp?id=156
Aug 30, 2009 | Shimano Dura-Ace SPD-SL Pedals
Look CLipless pedals won't stay clipped in
Check the alignment of the cleat. Make sure the cleat is straight in the pedal when your foot is going through the pedal stroke. You may be turning you foot allowing the pedal to unclip.
http://www.sansaworldmp3.com/
http://www.sansaworld.com/
Apr 06, 2009 | Pedals Look Quartz Grey Mtb Clipless ...
Cycling Logo
32 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
