Question about InFocus ScreenPlay 5000 Multimedia Projector
Infocus Screenplay 5000 - Pop - Gone!
Just installed the third bulb in the projector. It ran for about 6 hours at different intervals. The final episode was about 45 minutes total. The fans sped up, ran for about two minutes and POP!
Now normally if it overheats, I can pull the plug for a few minutes and the red LED turns green and we're back to normal.
I've tried different outlets and power cords but no matter the combination, no LED at all. There is a heat senstive switch in this projector. I've jumped the sensor and found that the LED still does not light.
I'm hoping for a hiddent fuse somewhere I don't see!
  • 2,237 Answers
The power supply is bad. there is a fuse on it, but it wouldn't be a occasional problem. the caps on the ps board may be drying up and causing it notto function. replace the ps.
Posted on Aug 03, 2009
I have an infocus 4805 screenplay projector and i was using it when there was a pop and then i lost all color in my projector now its only black and white the bulb filter is clean what do i do.
Your projector is DLP technology. It employs a "color wheel" to provide colors other than blank/white. That "pop" you heard unfortunately may have been a malfunction of the color wheel mechanism, probably the motor. (It runs at very high RPM)
Sounds like you may have to find a shop to service your projector.
Aug 15, 2010 | InFocus ScreenPlay 4805 Multimedia...
I detached and re-attached the cable to my infocus screenplay 5000 projector and now the picture is all red. The sync said that it is in green synch. I don't know what that means.
it could be your cable. try a new one. it could also be a lcd cable. if you can, make sure the cables are completely inserted into the main board.
Jul 04, 2010 | InFocus ScreenPlay 5000 Multimedia...
My infocus 5000 projector is not putting out yellow color is it the bulb or projector?
Your bulb provides the light,the projector provides the image so it would be your projector.
May 07, 2010 | InFocus ScreenPlay 5000 Multimedia...
I have a Infocus Screen Play 5000 bulb has 324 hours the picture is light green.
try reflashing the firmware, check your cables by wiggling the ends coming out of the projector and watch the picture for any changes, if it goes to normal at any time, your cables are just worn out. if that doesn't do the trick, maybe your lcd polarizers are burnt, i really need a better description of the picture.
Apr 01, 2010 | InFocus ScreenPlay 5000 Multimedia...
I replaced the bulb on my InFocus ScreenPlay 5000. The unit turns on the picture is showing a little green while the light warms up. After about a minute, the light turns off but the project remains on as...
there is an issue with the lamp ballast. probably needs to be replaced. send it in to an infocus service center. try av solutions in ny. they're really good.
i think it's www.avsolutionsny.com
Nov 23, 2009 | InFocus ScreenPlay 5000 Multimedia...
New lamp, no power!
if there are no leds lit, i'm surprised that it powers up. but if there is no light when the fans are running, it may be the ballast that needs replacing.
Oct 14, 2009 | InFocus ScreenPlay 5000 Multimedia...
Infocus SP 5000 loud electrical noise, then dead
check the lamp again. look in the reflection in the bell of the center glass. do you see any black spots or cracks or uneven bulging? if so, change the lamp and blow the dust out, because it may be over heating. otherwise, the power supply is fried and needs replacing.
Jul 03, 2009 | InFocus IN72 Multimedia Projector
Color wheel in my InFocus ScreenPlay 4805 projector
The 4805 Color wheel part number is 525-0146-00
You can buy it from AV SOLUTIONS in NY
As far as if it's worth it... That's up to you.
Nov 07, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus LP630
get it from projectordoctor.com or from infocus. do not get cheap replacements. you get what you pay for.
Sep 18, 2007 | 3M Projector lamp Projector Lamp
InFocus ScreenPlay 5000 Multimedia Projector Logo
342 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
