Probably due to damage in the headphone port, sound will only play out of the left speaker. This is with any set of headphones, so I know the headphones are not the issue. Is there anything I can do?
I think it's probably a damaged audio jack. If you're still in warranty, get it off to Apple. If not, you've got 3 choices;
1. Attempt to fix it yourself. I managed to get stereo again by opening the ipod up and inserting a staple in the bottom of the jack, to fit between the headphone and the ipod's audio input. This took some fiddling around, using tweezers, and will probably not last long if I take it out somewhere. I might attempt removing the audio jack and seeing if I can bend the metal connects for the right audio channel so they touch the headphone cable again. An alternative to this method would be to put some cardboard in the audio jack socket and adjusting it so that it brings the hardphones back into contact. Someone did this and posted the results on their blog, but I forgot the URL...
2. Buy a new audio jack and replace it yourself. There's an ipod repair wiki out there, and several of the replacement jack suppliers have detailed instructions. It's about 40 UK pounds for the replacement though....
3. Get someone to repair it. Expensive, about 60 quid, but perhaps worth it if you're scared of further damaging your precious beast.
Note though that there have also been issues with software updates and audio output, search the apple discussion boards for more details...
Short of actually repairing it, you can pick up a mono to stereo adapter for a couple a bucks at Radio Shack...
In diagnosing, I noticed that the damaged speaker side would give sound if the headphones were held a certain way. So,I jammed in a couple of short stands of speaker wire to make up for the slack. It worked immediately. My father taught me this trick in another context. Thanks dad.
One workaround (not cheap) is to buy the iPod Radio Remote, which plugs into the dock connector and provides another headphone jack. (However, this makes your headphone cord really long, and while this solution worked for me for a few months, now the Radio Remote itself seems to be broken in the same way.)
Read take some cotton off a Q-tip....dip in alcohol wring off most alcohol then clean inside....blow in the holeto dry the rest....it helped mine....didnt fix all the way though
The cotton solution above is a waste of time I´m affraid. The reason you headphones are cutting out is due to mechanical wear of the jack.
ipod audio repair
http://www.ipodrefresh.com
Sounds like a bad port (as mentioned here)
ipod headphone repair
Happened to me too. I only get sound out of one earphone, unless I hold the part that goes into the jack in a certain way. Lame indeed. I guess I'll be dealing with Apple now.
I actually tried the cotton solution (dipping a mostly stripped QTip into alcohol and swabbing the jack, then allowing to dry). So far it has worked. Why not give it a shot? The question becomes, what are you willing to try before dropping some serious cash on sending your iPod to a repair person?
I am having the same problem, sound from left speaker only, but right bass working, problem occuring in several devices that I connect to. Figured I might as well try I different output cable from my iPod, and problem solved. My initial cable (non working) had one black ring on the pin .. my cable that works has two black rings (apologize, I am not a techy so do not know the lingo).
The Laptop has 3 Ports on the
side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the
Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone
- into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers
One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it
Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone
sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select
manage audio devices then recording you should see a microphone right click
select enable windows 7
and sound then select manage audio devices then recording you should see a
microphone right click select configure
speech recognition then
you will see earphones with a speaker among a list set
up a microphone headset with microphone
then next and next again you
should see your earphones with microphone being configured
sounds and audio devices select advanced there might be a tick in the mute box
untick it or select audio from the microphone drop down list
make sure you have the right
one selected and in the volume box make sure the microphone box has a tick in
it or
select the voice tab
make sure that you have the
right media selected also
select volume make sure the
box for microphone has a tick in it
or you might have to depending
on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as
default
select that!!
then when you disconnect your
headphones it automatically switches to the speakers and when you plug them
back in it automatically will switch to headphones
Hope this helps.
i only get sound out of the left speaker and not the right with evrey earphones what to do?
I think I have fully damaged the connection between the ipod and the headphone jack by using a slightly too-long headphone jack (although still 1/4"). I inserted the headphones, pushed them the wrong way, and now the ipod runs perfectly but absolutely no sound is coming out! is there a way to have this physically repaired?
Sound out of only one speaker/headphone (the left), can get sound out of the right if I really jam the headphone jack in. Ugh, so annoying. This is the second ipod this has happened to, anybody know how I can avoid damaging the headphone jack?
sound only comes out of my left speaker. but, when i don't plug in my headphones all the way they both work. i've been through so many headphones, and i still have the same problem.
only have sound out of left ear phone. have tried several new headphones and earbuds. nothing seems to give me that great sound back :(
Hey, I have the exact same problem, supposedly it's caused by wrapping your headphones around the device too tightly, causing stress on the headphone jack.
No matter what I play it out of, whether it be headphones or speakers, only the left speaker works. The same goes for my car. I have the black 30 gb video idpod as well. What can I do?
At first I thought it was my headphones, so I went out and bought a new pair. It turns out its the same problem with the new ones. Only one ear works. So we assumed it was an internal problem. I'm not sure at all what to do. Please help.
my ipod plays but has no sound, changed the headphones and still has the same problem also i pluged it into the usb port to listen to music and no sound. any ideas?
only the left ear has sound
yeah mine is only playing out of the left speaker too
I tried about 5 other headphones and it is the same problem throughout
I'm afraid I will have to buy a new iPod
it only plays out of the right headfone is there anyway i can fix this??
my ipod does the same thing. I'm sure its not the headphones because i just got some new ones to be sure. Any ideas to fix this?
iPod headphone jack lost right channel so I went to Radio Shack and picked up an "L" shaped mono to stereo adapter for a couple a bucks and works just dandy.
I cant get sound out of any side of the speaker
