Question about Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL CLEANER -
Do other brand name pumps work with a polaris 380 or do i need to use the polaris pump?
    Problem Solver:
  • 16 Answers
You can use a hayward booster pump or pentair letro booster pump also
Posted on Jan 16, 2010
  • 27 Answers
The Hayward booster pump would work but being in the same price range the Polaris is engineered for its cleaner
Posted on Jul 20, 2009
Hayward great white just spins in circles
Could you clarify the exact model? The picture shows a Polaris 380, and the Great White is built by Sta-Rite/ Pentair,(now sold under the name Kreepy Krauly), not Hayward.
Confused yet? Don't feel bad, I am too!
Sep 15, 2013 | Polaris 380 In Ground Pool Cleaner
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
My brand new Polaris 380 booster pump is noisy. What do I do?
Thank you for posting your question here on Fixya.com.
It is likely due to cavitation in the booster pump impeller. The easiest way to correct the issue is to slowly close a throttling valve on the booster discharge. If there is not one present install a ball or gate valve near the pump discharge line and slowly close it with everything running until the noise stops. Generally speaking closing the valve about a quarter of the way seems to be when most pumps run quietly but the setting is unique to each installation.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
May 14, 2011 | Polaris 380: Polaris Booster Pump
Need picture of hose set up for polaris 380. Not just the diagram but an actual picture of it assembled. Thanks
should be a return outlet half way in pool closest to pump install fitting into wall connect Polaris and turn on filter pump and booster pump should move around pool adjust screw on back bottom for tail
Apr 29, 2010 | Polaris 380: Polaris Booster Pump
Which pressure should i use on uwf polaris assembly 380
It might not be your booster pump. First, check the filter screen and clean if necessary. Often, this is the only problem when these pool cleaners are having problems. Clean the skimmer, pump, and filter also. You will also want to check all connections and hoses to make sure that you don't have a leak.
Mar 14, 2010 | Polaris 380: Polaris Booster Pump
I installed a booster pump. Attached a one ince
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
Jul 16, 2009 | Polaris 380 In Ground Pool Cleaner
The polaris booster pump motor does not start. I hear it humming. I took the end cap off and turned the shaft without a problem. I took off the capacitor and tested it and it works. What should I check...
I my name is Juan and I was a pool repair tech in california and if your capacitor is good and your motor turns freedly with your hand then is time to replace your motor for a new one if you planing to do this make sure you replace the water seal is a good time to do it
Jun 16, 2009 | Polaris 380: Polaris Booster Pump
Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL CLEANER - Logo
153 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
