Question about Kenmore Oasis 27042 Top Load Washer
At the begining of the cycle a F1 code flashes, what does that mean? we don't have manual
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
5 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: cycle begins then shortly after
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: my washer keeps stopping during the cycle and
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
SOURCE: Have a Whirlpool Cabrio top
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Posted on Aug 23, 2011
emissionwiz
  • 80339 Answers
SOURCE: F1_Code on a whirlpool washer
F1 is a failure of the primary control circuit board and is a fairly expensive repair. This is a factory defect that Whirlpool is aware of, call them and request factory assistance to repair the problem.
Posted on Oct 27, 2011
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
I keep getting an F1 error code on my whirlpool elite washer at beginning of cycle and at beginning of rinse cycle, why?
F1 error code usually refers to a control board or touch pad failure in a whirlpool washer.
Hope this helps if you have any further questions message me back Thanks Rick
Jul 17, 2011 | Washing Machines
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies.
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
On fill-up washer stops and a code of F1 shows,YOU OPEN LID AND SHUT 1-2 TIMES AND IT WILL CONTINUE TO FILL OR COMPLETE WASH CYCLE..I also can't find my manual is it possible to purchase another?
Hi, carbio began flashing the F1 error code at 18 months. I have to hit the pause/start 4 or 5 times to get the cycle to begin. It also flashes occasionally at the rinse cycle (17 min.) I have called Whirlpool 3 times with little satisfaction. They have offered to pay for the part, but I will be responsible for the service call, diagnostic fee, and labor. I am not satisfied with this offer. It is obvious to me with so many others experiencing the same problem that Whirlpool has a quality issue with this machine. The sales rep who sold me the machine said to call Whirlpool everyday until they are sick of hearing from me. The more calls logged about the complaint, the better chance of a recall on the machine.
We have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Take care
Jun 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does f1 mean?
Hi, my Carbio began flashing the F1 error code at 18 months. I have to hit the pause/start 4 or 5 times to get the cycle to begin. It also flashes occasionally at the rinse cycle (17 min.) I have called Whirlpool 3 times with little satisfaction. They have offered to pay for the part, but I will be responsible for the service call, diagnostic fee, and labor. I am not satisfied with this offer. It is obvious to me with so many others experiencing the same problem that Whirlpool has a quality issue with this machine. The sales rep who sold me the machine said to call Whirlpool everyday until they are sick of hearing from me. The more calls logged about the complaint, the better chance of a recall on the machine. If this is not resolved.
Take care
May 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F1 Error code on fisher paykel softouch dishwasher
F1 means that water is in your basepan--- you can pull the bottom drawer out and soak up the water with a towel... you will have to use a hair dryer to dry underneath the control sensor in the back left corner.
Apr 11, 2009 | Fisher Dishwashers
Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Feb 13, 2009 | Whirlpool Washing Machines
My kenmore oasis elite flashes f1 and wont run it's cycle? Can't find my manual.
The F1 error code indicates either that the pressure signal is out of range or the pressure hose is blocked. This would mean that the control board is defective or the pressure hose is pinched or blocked somewhere between the control board & the outer tub. You can check the pressure hose by removing the rear panel & looking where the drain hose is coming out of the back of the cabinet.
Jan 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 Alarm @ rinse cycle
F1 code = Primary Control Failure. Replace the machine/motor control assembly. If you use a screw driver in front of the machine to open the top you will find a repair manual on the inside of the front panel. or depending on the model, you can even unscrew the bottom and find the manual.The manual inside is actually meant for technicians.It contains the error codes and instructions related to them.will be looking forward for your comments if there is any further problem in this.
Dec 15, 2008 | Whirlpool Washing Machines
Kenmore Oasis 27042 Top Load Washer Logo
35 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
