Question about Bryant 462AJC021BA Air Conditioner
A/c is not working. The outdoor fan is not turning i can hear the unit turning on but no fan
  • 1,056 Answers
Try turning the fan with wooden a stick, if it runs then the fan is bad, replace it.
Posted on Jun 30, 2009
  • 1462 Answers
SOURCE: The fan in the outdoor unit does not work while the AC is on.
fault may be just the fan. check if stiff to rotate for starters and then check continuity thro it
Posted on Apr 24, 2007
  • 21 Answers
SOURCE: split unit, I get heat but no cold
Unit will not run unless both indoor fan coils are in cool mode.
Posted on May 22, 2009
panilling9
  • 284 Answers
SOURCE: heat pump not running
check your house circuit breakers first that should be labeled heatpump or outdoor unit
make sure it is on and or not tripped
then if you have a box outside near the outdoor unit open it up and see if there is a breaker or maybe fuses that could be blown
Posted on May 26, 2009
FunnyPlumber
  • 43 Answers
SOURCE: We have a new house and it came with central air.
First check to be sure the circuit breaker for the outside unit is not tripped. Turn the two pole breaker all the way off all the way off and then back on. If the outside unit still does not run you may have fuses in a disconnect box by the outside unit that are blown. You can check them with an OHM meter. No OHM reading means they are good.
The low hum you hear is probably the control voltage from the thermostat pulling in the contactor (switch that starts the outside unit). If no line voltage (230 VAC) comes to the unit it will not run.
Posted on Jun 24, 2009
james3751
  • 614 Answers
SOURCE: outdoor unit fan making noise when running sounds
Bearing in fan going out. Let it run till it quits or call service tech to change motor. Fix cost about 250 to 300 dollars. russ
Posted on Jul 22, 2009
My outdoor compressor won't kick on and thermostat is not showing current temperature
sounds like a bad tstat. turn power off to indoor unit, put the red green and yellow together with a wire nut at the tstat in order to bypass and turn power back on. if EVERYTHING works you have a bad Tstat.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 09, 2017 | Heating & Cooling
Air was not cooling but indoor fan was working. Checked outdoor unit, fan not working and hearing like a vibrating/humming sound.
If the condenser coil is very dirty it may have tripped a manual reset high pressure switch try and locate it on the condenser , Also check breaker feeding unit. If it comes back on turn off at the thermostat and wash condenser coil with a garden hose .
Oct 12, 2015 | Heating & Cooling
I have a Honeywell thermostat. The thermostat clicks to turn the air condition on but the outdoor unit does not turn on. The fan clicks on though.
I assume you are referring to the indoor fan coming on. If the fan on the outdoor unit is coming on, and the compressor is not, you have a control problem with the outdoor unit, I recommend calling a service man. Make sure you have power to the outdoor unit. There should be a service disconnect on the outdoor unit, connect and disconnect the power, you should hear a hum when the power comes on, put your ear to the housing of the outdoor unit and you will hear the power come on when it is turned on. If no power, or hum, check your breakers in the house electrical panel, see if any are tripped. Next step call a service tech.
Jul 20, 2014 | Heating & Cooling
My outside Kelvinator central ac unit will not turn on. I hear a faint humming noise coming from it so it appears that it is getting power but won't turn on. My fan in the house will turn on and...
Its possible that the contactor that closes to start the outdoor unit is not pulling in and passing power. You are hearing the coil humming since it is getting control power. Also first check that breaker for outdoor unit is not tripped
Jun 22, 2011 | Heating & Cooling
I replaced the fuses with the proper ones thinking that that was why fan on ac unit was not on. I did the 24 hour off on electrical panel, and replaced fuses, now i hear a click then a humming sound coming...
The humm you hear is the compressor. Turn your unit on and let it run for a couple minutes and grab the large pipe at the outdoor unit. If it's cold, your compressor is running. If your fan didn't turn on, there is a good chance your motor is fried. It could be your contactor, but I doubt it. The compressor and fan are wired through the same contactor, so when one comes on, so does the other. DO NOT run your unit for more than a minute or two with the outdoor fan not running. If you continue to run it, it's going to go out on high pressure and turn back on, and so on, and so on, until it fries the compressor.
Sep 28, 2010 | Carrier Heating & Cooling
The unit is not communicating between the Furance and the AC
Then it is not communicating with the thermostat. When you turn it to cooling and the fan comes on, then the thermostat is communicating
with the furnace.
If you have 24volts between Y and C then it is communicating with the AC Unit. If you go outside and remove the electrical panel(shut off power
to outdoor unit) you can still hear the contactor being pulled in.
If you cannot hear that you need a new two wire from furnace to outdoor unit
Jul 16, 2010 | Ruud UAMB024 Air Conditioner
Heat pump not running
May 26, 2009 | Goodman CPLE24-1 Air Conditioner
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Bryant 462AJC021BA Air Conditioner Logo
520 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
