Question about Philips FR975 Receiver
No Sound All pieces are connected properly.
  • 776 Answers
Check the outlet. Check power cord is plugged in tightly.
Then change fuse (you will have to open the case for this one).
There is a chance of a bigger failure than fuse - Manual is available at philips.com website - see...
http://download.p4c.philips.com/files/f/fr975_01c/fr975_01c_dfu_eng.pdf
This is the best I can offer with limited information.
Posted on Mar 30, 2010
Control pod failure on bose companion speakers , the sound stops
check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
Mar 06, 2015 | Bose Companion 5 Multimedia Speaker System...
I have a Kenwood kac-628 amp and it turns on but only red lights. All wires are good and have good connections. I opened it up and there is a brass looking piece that seems broke. Maybe a piece is missing...
Disconnect the speaker wires from the amp side. Turn the amp on. Within about 5 seconds you should hear a faint click from the amp. If you don't hear the click, the amp probably has a problem. ie. Shorted outputs. If you hear the click reconnect one speaker and turn on again. If you don't hear sound disconnect that speaker and connect the other. If you have sound with either speaker the one that is disconnected is the problem. Check speaker wire carefully for frayed ends touching each other.
You can swap the speakers at the speaker end one at a time, to determine if it is the speaker or the. Wire.
Feb 02, 2015 | Kenwood Car Audio & Video
Getting no sound hooked up to pre-amp and 2 rotel 200w amps with snell speakers
You didn't say whether the player is connected by 2 RCA cables (analog) or by digital cable. If by RCA, does the player have a headphone jack? I had a player once with a piece of a headphone that broke off inside the jack, muting the analog outputs.
May 16, 2014 | Sony CDP-CX300 CD Player
EAR PIECE REPLACEMENT
How to check and correct a bad Ear Piece
Equipments Needed
Digital and Analog Meter
Procedures to Follow
Step 1: Check and read your ear piece to see if it's good
Step 2: Check if the terminal is connected on the board interface.
Step 3: If it is not connected, clean well and make it connect.
Step 4: Read the board interface to see if it is reading continually, if it isn't, loop for sound.
Step 5: If it's a flip up phone and the phone interface is not reading, you have to replace the flex to obtain sound.
Take care
Apr 17, 2010 | Samsung SGH-D900 Cellular Phone
EAR PIECE REPLACEMENT HELP NEEDED PLEASE INSTRUCTIONS IF POSSIBLE
Equipments Needed
Jan 11, 2010 | Nokia e65 Cellular Phone
No Sound
check the drivers are installed properly
or reinstall drivers if the problem is not rectified the u hv to formate ur system
Jan 23, 2009 | Computers & Internet
No sound
I had this problem as well. I would get sound from headphones but unplugging them I had no sound from the builtin speaker.
When you plug in your headphones it moves a thin piece of metal in the jack which interrupts a connection (this is a good thing) so it can know when to disable the internal speaker. When you unplug your headphones the piece of metal moves back and it enables the internal speaker again.
I was able to fix this by taking apart my x51v and bending the piece of metal a little while the headphones are plugged in so that it will contact better when the headphones are unplugged,
To take your axim apart there are 4 screws on the back underneath the rubber grips that you need to take out. Then you can just slide a finger nail up and down each side to remove the front and back of the casing. The back you will need to swing out from the bottom since it hooks over the headphone jack. I unplugged the small wire that connects the front half of the case to the guts using a tiny flat screwdriver.
Inside on the back, there is a black plastic plate that is held on by 4 more screws. Take that off.
Now you can see the headphone jack. I plugged in my headphones and used a small flat screwdriver to push against the headphone jack on the bottom piece of metal on the right side with the axim face down. You can observe the piece I mean by looking at the side of the headphone jack when you plug and unplug headphones. It moves perhaps 1/32 of an inch.
Your goal is to bend the piece of metal closer to where it is when no headphones are plugged in. The only way to bend it properly is to do it when the headphones are in.
Sorry if this isn't clear enough. I'm not sure if this is a permanent fix or not but it's worked for me.
Jan 04, 2009 | Dell Axim X51v Pocket PC
Cannot get sound to come out of earpiece after pushing button on top of i870
sir u have to see that earphone i properly plugged to the phone...nor ur ear piece dameaged....
Oct 18, 2008 | Nextel Cell Phones
Ear phone not working
If it is not your headphones then try checking the connections. Remove the back and check the connections to the audio socket. They may need re-soldering to the main circuit board.
Hope this helps,
Mowcius
Jul 02, 2008 | Rio Carbon MP3 Player
Logitech Speaker Help
Unfortunately, Logitech doesn't sell the wired remote controller separately. And that seems to be infamous for going out.
What worked for me (with no sound and no blue light on the remote connector) was to plug a set of earphones into the earphone port. As soon as I did that, the blue light came on and the sound was restored, even after removing the earphones. Someone else said both speakers worked properly while they had the earphones in, but not otherwise.
Mar 18, 2008 | Logitech Z-2300 Computer Speakers
Philips FR975 Receiver Logo
105 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
