Not blowing cool air, filter is clean. cant understand why all of a sudden the air is not cool
    Sergeant:
    Champion:
  • 235 Answers
Is the compressor running. ?
Posted on Jun 30, 2009
Compressor comes on but wont blow cold air
Hello jpaul, I understand that your air conditioner is not cooling properly. Here are some simple troubleshooting tips to help resolve this issue:
· When was the last time the filter was cleaned? Restricted air flow from a soiled air filter can cause air conditioner to not cool properly. Make sure there is nothing blocking the airflow to the unit like blinds, drapes, furniture, etc which could restrict air distribution.
· Confirm that the condenser coil is clean and not restricted by any trees, bushes, etc since the coils could possibly be blocked or dirty.
· Verify that the plug is not damaged and try resetting the unit. This can be done by pressing the GFI plug on the unit.
· Do not use an extension cord.
If issue persists, I would suggest contacting an experienced service technician to determine the precise cause.
Jul 31, 2013 | Frigidaire Heating & Cooling
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Air Conditioner isn't blowing cold air
There are a few thing's that can cause this, if the evaporator coil in the a/c is blocked a little, you could get a little cool air, it's like having a dirty filter. If the condenser coil is blocked, you won't get cold air. If the refrigerant is low, you won't get cold, cold air.
Jul 19, 2013 | Amcor Heating & Cooling
Air conditioner model 585CJ02450 doens't blow out cool air during the day at night blows cool air can I clean the filters and radiator
Was there any resolution? mine does the same it runs blows the fuse, but doesn't blow air out I would have liked to see what your resolution was.
Jul 12, 2012 | Heating & Cooling
Aircon is only blowing ambient air with no cooling effect. the indoor and out door unit appear to be operating normally. am I out of gas or is the compressor not running? what could cause this to suddenly...
First of all check your compressor is working with correct amps. If yes, service your unit to improve better cooling. If compressor not working find out the root cause for it. Please call repairman to find the fault.
We can only give solution by having particular cause or error code is stated by you.
And also follow these tips always:
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 16, 2011 | Fujitsu 18C1 Air Conditioner
Turbo air not blowing cold air
10 minutes?? So he added the gas and jumped in his truck and left?? WHAT COULD REALLY HAVE HAPPENED?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 23, 2018 | Turboair TAS-24H Split System Air...
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Ac cooling but not blowing very hard
The AC filter of your car should be under the dashboard on the passenger side. While you have it opened it would be best to go right ahead and have other components clean to save you time.
Jul 22, 2009 | 1996 Saturn SL
Air Handler Blower
if you have a meat thermometer, place it in the vent when the air is on, it should be cooling somewhere around 15-18 degrees F lower than what actually temp is, so if its 84 degrees, your unit should blow around 67 degree air out of the vent. if it is not call a tech. your system could be under or over charged.
Jun 21, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
