My dvd rom not appear on my computer.. but in device manager exist and working properly.. my laptop toshiba satellite pro 6000 any sugestion My LCD scrambled with horizontal line..is it the LCD problem or any other cause...?? but when i use external monitor.. it working well
  • 453 Answers
Hello !
Here you go !!!
All you need to do is go
  1. Click Start
    my dvd rom not appear on  my computer.. but in - vistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. For Windows XP (Click Start -> Run)
  4. Type regedit, and then click OK. securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  5. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  6. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  7. On the Edit menu, click Delete.
  8. When you are prompted to confirm the deletion, click Yes.
  9. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  10. On the Edit menu, click Delete.
  11. When you are prompted to confirm the deletion, click Yes.
  12. Exit Registry Editor.
  13. Restart the computer.
Posted on Jun 30, 2009
Toshiba laptop lan problem
i dont understand does appear when connecting rj45 wire on lan ??
if you mean you cant see your cd drive on your computer
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jul 31, 2012 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
HOW CAN I RESTORE TOSHIBA SATELLITE A205-S5804, I JUST WANT TO RESTORE MY LAPTOP TO FACTORY
I am glad to HELP YOU!
You will need to use RESTORE PARTITION [existing on your hard drive] or the RECOVERY DISKS.
Some details you have HERE.
GOOD LUCK!
... and don't forget to RATE, please...
Apr 26, 2011 | Toshiba Satellite A205-S5804 Notebook
My Toshiba Satellite Pro, when I turn my laptop the screen comes on with Password= I forgot my password, how do I reset it?
The first question is - did you create a password recovery disk? If not you will have to re-install the operating system.
Your BIOS default will be set to start up from teh DVD drvie - insert the recovery disk and it will re-install the operating system.
Dec 18, 2010 | Toshiba Satellite Pro 6000 and 6100 14.1...
My cd/dvd rom drive does not appear. It's as if it does not exist when you try to access it through My Computer or any other way.
go to device manager and check there for troubleshoot , clean up ur registry key for driver use reginout cleaner may fix it
Oct 11, 2010 | Toshiba Satellite A105-S4334 Notebook
Cant find dvd rom?
If you can't find the DVD ROM, try to click the start button, then click My Computer. Then try to find if the opticcal drive / DVD drive exist on it. If it is not, try other options..
You may uninstall it from the device manager by clicking Start > right click My Computer > then click Properties > then click Hardware > then click Device Manager. Under DVD/CD ROM drives, right click the device and Uninstall. Then restart the pc and go back to device manager. Then click Scan for hardware changes let it auto install the drivers. Check if it works....
Sep 20, 2010 | Toshiba Satellite M105-S1021 Notebook
Does the Toshiba Satellite Pro 6000 have a
The Toshiba Satellite pro 6000 doesn't have a built in microphone as far as I can remember but it does have a microphone socket at the front next to the headphone socket. Both sockets are on the bottom left hand side left if looking from the front. The microphone one is the one on the left, if you look closely there are symbols next to each of the sockets, one looks like headphones the other like a microphone.
Hope that helps
Chris
Jul 03, 2009 | Toshiba Satellite Pro 6000 and 6100 14.1...
DVD RAM not reading the DVD on a Toshiba Satellite A105 laptop
did you try to insert other DVDs? if it works then the DVD that you are trying to play is faulty. But if all CDs cannot be read i suspected it's a dvd-rom drive faulty. you need to replace it.
May 28, 2009 | Toshiba Satellite A105 Notebook
TOSHIBA SATELLIT A105-S4244
Does it show up in xp as being there? Will it spin up when disk is put in? Is it both dvds and cds it wont read?
Jan 06, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
David Payne
David Payne
