Power window switch on drivers side not workin
Check the fuse first, each power window has it own circuit as they draw a lot of power. You owners manual will have a fuse chart and where they are. If the fuse is OK, try and pry out the switch, or in some Pontiac's they come out with part of the panel. Check to see if the wires are connected or that they are not damaged. If they are OK, get a switch from another window and hook it up to the bad one. If this works then you need a new window switch.
