Home | Bissell | 7901-1 ProHeat Scotchgard Upright Wet... | It says it is a Bis...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Problem for Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
It says it is a Bissell 12 Amps Pro Heat with
By ramona_doda on Jun 30, 2009
It says it is a Bissell 12 Amps Pro Heat with Safeguard, and a light indicator on it. So basically it is not spraying out water. I just got it serviced today and cleaned.
Solution #1
posted on Jun 30, 2009
Somewhat Helpful)
ghost4548
Rank: Guru
Rating: 86%, 320 votes
Take it back to the place where you had it service/cleaned and tell them to do it RIGHT!
Was this helpful?
Yes
No
Popular Solutions for Bissell 7901-1 ProHeat
Questions and Unsolved Problems for Bissell 7901-1 ProHeat
Do you recommend Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum?
Answer
Answer
7901 series carpet cleaner sprays but does not **** the water back up. Got it appart right now and... (More)
Answer
Bissell Proheat Plus Model 7901-P won't spray out cleaning solution, but does **** up liquids. What... (More)
Answer
it will not **** the water back up but it the suction is working on the base part below the water... (More)
Answer
it'swork in reverse. The roller spins when it's upright and stop when yo relaease the foot tab. How... (More)
Answer
7901 problem with no spray, pull trigger, but nothing comes out...pull out the bladder container,... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bissell 7901-1 ProHeat...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
