Question about Goodman CKL24AR24 Air Conditioner
No cool air some rooms: Lennox G40UH
I have a Lennox G40UH cental a/c that blows no air to some rooms downstairs and is too cold in some rooms upstairs. I have one unit and 2 storied home and am afraid my a/c is going to give up on me any day now! Any advice in why it is failing on some rooms? Any simple fix out there? If I have pay get it fixed; how much can I expect it to run into?
Thanks
Sm
    Sergeant:
    Champion:
  • 235 Answers
Sounds like a restriction of air flow. Check you duct work and check for holes or lose duct.
Posted on Jun 30, 2009
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Lennox 10HPB36-10P is blowing luke warm air.
What coil is getting cold? In cooling the evaporator coil should be getting cold not the outdoor condensing coil. Verify you have the tstat setup for heat pump, verify you have a proper refrigerant charge.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 19, 2017 | Heating & Cooling
We have 2 units (upstairs and downstairs) the upper unit no longer cools, we've had several calls done and a coil was replaced, issue persists and it will not cool below 85 degrees. The downstairs unit...
Check the supply air tempeture and the retun air temp.. to do this you put a termitor where the air come out and take the temp. then you check the air at the return where it goes back to the blower. you shoudl see a 15-20 degree diffrence. the oterh thing MIGHT be that cold air is heavier than warm air so it sinks down stairs. close off all the rooms upstairs might help .
Jul 18, 2011 | Heating & Cooling
Cold air blows outside and hot air inside
Make sure it is in cooling mode. Sounds like you may have a problem with the reversing valve but you would want to check the pressures in the system first and make sure the charge isn't low.
May 02, 2010 | Heating & Cooling
One of 2 Lennox AC units not working well.
check the filters if it needs cleaning....or check the refrigerant level if it is below normal
Aug 11, 2009 | Heating & Cooling
Lennox G40UH(x) series - Air not coming on
electrical connections @ the furnace may the thermostat .Tom
Jun 18, 2009 | Heating & Cooling
Stand alone AC blows cool air but does not cool the room
send tank capacity.model mail me mintex007@yahoo.com
Oct 09, 2007 | Heating & Cooling
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Goodman CKL24AR24 Air Conditioner Logo
204 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
