Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Is there a deck switch on a YTH180
I have a YTH 180 riding lawn mower when brake is released engine dies. When blades are engaged engine dies. Is there a deck switch on this model and where is it located?
    Problem Solver:
  • 23 Answers
Brake shutoff isn't working properly it is located on opposite side of brake about 3inches past steel plate unplug and put jumper wire from white to white wire this will disable brake shut off.this is only a suggestion but it will work.
Posted on Jun 02, 2012
  • 218 Answers
Hi..my name is Keith...and i havent worked on that lawn mower model..so i cant tell you exactly where the safety switch is..but it sounds like the reverse safety switch has failed and the lawn mower thinks you are in reverse..so i would look around your foward-neutral-reverse shifter for it...i hope this has helped..if not write me back
Posted on Jul 01, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why does engine die when brake released or mower engaged?
The first thing I would check is to make sure the drive belt is not binding somewhere.
May 17, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What causes a riding mower to die when engaging the blade
safety switch in the seat and in the brake. if one of those is open, engine will die when you engage the blades. Owners manual should have wiring diagram so you can bypass switches to test (if you have brake applied and are sitting in the seat and that is when it is dying).
May 04, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When i release the brake on my mower the engine dies if i push it back down immediately it will continue to run
Check your seat switch. If there is someone in the seat, the brake can be released and/or the blades can be engaged. If you can do neither, the seat switch is not opening.
Let us know,
Your Fixya Tech, Gary
Aug 15, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a husqvarna riding mower and when i turn it on and release the brake the mower dies and when i put the blade on or give it gas it dies, but for the most part just releasing the brake after letting...
It sounds like the seat switch is not working. This switch must be made by a person sitting in the seat for the brake to be released or for the blades to be engaged. It is possible to start the mower with the switch open.
Gary
Jul 03, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Release brake engine dies engage blades engine dies
there is a saftey switch on the deck that has shorted out need to replace
Jun 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Mar 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower dies when i try to engage blade
Hi, what you wrote is exactly what's is suppose to do. what is it about the mower that's not doing?
Nov 22, 2008 | Craftsman 20 Hp 42" Deck Lawn Tractor
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
635 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
