Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
52 inch Toshiba... the picture is narrow for the first 15 minutes and then it is fine after that.
  • 767 Answers
Its a cap on the convergance board
they can be kind of tuff to find some times
Posted on Jun 30, 2009
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
I just replaced the lamp in my tv, it will work fine for 10-15 minutes, after that the picture will start to flicker and then just go out completley and th lamp light will blink on the tv set, what could...
My 50HM66 did the same thing. Try putting a fan to the side of the tv so it blows cool air around the back. I also removed lamp and vaccuumed as best I could. I think this is an overheating issue with the tv.
Sep 03, 2010 | Toshiba 50HM66 52" Television
52 inch Toshiba rear projection no picture has sound
You have bad solder connections in the deflection circuit. Call a good TV tech unless you know what you are doing. You could get an electrical shock from a charged capacitor.
Jul 06, 2009 | Toshiba 57H81 57" Rear Projection...
Half my screen is soild white the other half is perfect
one of the ribbon cables connecting lcd control board an lcd panel is not sitting properly or connector is not locked.
May 09, 2009 | Sharp LC52D65U 52 in. LCD TV
RCA Scenium
What does the picture look like when it is on?
Dec 03, 2008 | RCA Scenium D40W20 40" Rear Projection...
Toshiba 32 inch 8year old tv set
Probably a bad connection on the tube base but your CF32H50 model dates from 1998!
Jan 28, 2018 | Toshiba CF32G40 32" TV
Toshiba 52
MAKE SURE THE BALLATS MAKE NOISE . IF IT DOES YOU HAVE PROBLEM WITH LAMP.......
May 02, 2008 | Toshiba 52HMX84 52" Rear Projection...
Picture in narrow line on 35" Tube set
The problem you are describing is called loss of verticle deflection. You will find this will require diagnosis and there is no simple answer to this repair. Most likely there will be either bad electrolytic caps or bad vert. output IC in the vert. circuit.
Mar 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 52 inch flatscreen
I have just completed removing tha base from a Toshiba 52 inch HDTV. There are 5 screws in total. Three about 8 inches form the base and another 2 about 4 inches from the base in the arrangement shown below
(X) is a screw
(l) center line
X X X 3 screws 8 inches from base
X l X 2 screws 4 inches from base
______l______ The base
Keep your feet clear as your undoing the last screw..the base slides out vertically downward and weighs about 10-15 pounds so keep your the toes, fingers etc safe. The risk of being sued may explain why Toshiba didn't this publish in the US manual.
Feb 24, 2008 | Televison & Video
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
