I was working on my laptop when it prowered down.
I was working on my laptop when it powered down. It was "sleeping" and I plugged it in to re-charge. When I tried to start it up the next day all I get is the apple with the circle going around and around. When I take the battery out it still happens. Help please.
  • 55 Answers
To fix this boot with the install CD that came with the mac. When you reboot hold down the "C" key. This should bring you to the install page. select the language and follow the instructions. when it asks to install or repair. hit repair. hope this helps you.
Posted on Jun 30, 2009
Should the light be onwhen thelabtop is shut off.
If you mean the charge light when the power is plugged in, yes. If you mean the standby/sleep light then it is probably not shut down at all, just in sleep mode or hibernate.
Nov 25, 2016 | Computers & Internet
Toshiba satellite pro does not fully shutdown
In Control Panel, select Power Options, you didn't post your OS?, set to High Performance, open Change Plan settings, set Computer Sleep Never, open Change Advanced power settings, scroll through the settings, set Sleep and Hibernate to Never, open Power Buttons and Lid, set to shut down. Now the red X on the Battery Icon usually means the battery needs replacing, it's not charging. Shut down the Laptop unplug, remove battery, plug in , reboot.
May 12, 2013 | Toshiba Satellite Computers & Internet
Laptop shut down and wont power up
Unplug, remove battery, check for dust in fans and vents, plug in, try to reboot. If it powers up, open Control Panel, Power Options Power , set to High Performance, open Advanced Power settings, set Sleep and Hibernate to Never, Adjust other Advanced settings to your preference. Has it been pulled by the cord? If you have a multimeter check for DC volts at the AC jack plug, that plugs into the laptop. Is the Transformer (brick on the cord) getting warm when plug in? Does the battery charge LED light? Try another cord with the EXACT same power specs.
Jan 23, 2013 | ASUS G73SW3DE Republic of Gamers 173Inch...
When laptop charging in off position and if i connect usb pen drive, ext. HDD, etc. these are on and flashing
Is the laptop off or Hibernating? Sleeping? Open the Control Panel, Power Options, Set to High Performance, open Advanced Power settings, set Hibernate and Sleep to Never. Shut down the laptop at the Start Menu. If the AC cord is plugged in the battery will charge. Nothing else should work.
Jan 16, 2013 | Lenovo 3000 C200 CM 520 1.6G 512MB...
Sony vaio laptop shutting down while plugged in
If it's left on for a period of time, specified by the power settings, it will dim the display, Hibernate, Sleep, etc. In the Control Panel, Power settings, Advanced Power setting , Change to High Preformance, adjust Hibernate and Sleep to Never, adjust advanced power setting to your specs. Shut down and unplug laptop , remove battery, when not in use, if you use on AC most of the time remove battery.
Jan 05, 2013 | Computers & Internet
My Toshiba's laptop's sleep and charge USB port
It's possible to fix. First go to device manager and you should see something like "USB Root Hub". Double click to open it, go over to power management, and "Uncheck" "Allow this computer to turn off this device to save power". Do this for all that say USB Root Hub. Next go to "Power Options" then "Edit Plan Settings" (accessible through "choose when to put the computer to sleep") and select "Change Advanced Power Settings". Next, make sure you do this in all of your power settings, but scroll down to an icon called USB settings. Expand the selection, then expand the "USB selective suspend setting". Choose, both on battery and plugged in if you want, to Disable the selective suspend. Finish and apply. Also, to confirm, you know that the USB device (IPod) but be plugged into the eSATA port, correct? It doubles as a USB port and is the only one capable of charging.
Mar 29, 2010 | Computers & Internet
The Toshiba Tecra A8 S8413 laptop cmos battery (or capacitor?) does not seem to be working. Symptoms: I set the date and time. As long as the laptop does not sleep or go into power save mode the clock...
The RTC (Real Time Clock) battery charges when the computer in on (operating). You can plug the electrical cord in and let the computer run for 24 hours by temporarily suspending any sleep mode or automatic power saving features. This should sufficiently charge the RTC battery.
Nov 30, 2009 | Toshiba Tecra A8-S8513 Notebook
Laptop keeps shutting itself off
Check the power settings - most laptops are set to sleep even if plugged in to AC power - go to Control Panel -> Power Options and check for sleep/shutdown settings under "Plugged In".
Oct 20, 2009 | Computers & Internet
My netbook wont boot, i turn it on and i will hear the fan but nothing else, i was using it everything was going well, the batery ran out and it went into sleep mode, i pluged it in and since then i canot...
Leave it plugged in for about 10 minutes. The battery just needs to charge a little more. Then you can come out of sleep mode.
If it is locked in sleep mode. Just hold the power button down to shut off the computer. Let it charge, you can now reboot, and keep charging after about ten minutes.
Jun 28, 2009 | Acer Aspire 5100 Notebook
My Laptop Will not sleep on AC Charge
Try using Power Options in the Control Panel. Define exactly how you want laptop to behave with either battery or AC.
May 23, 2009 | Toshiba Satellite A60-S1561 Notebook
Open Questions:
Cloud storage and file storage - DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jul 20, 2018 | Quantum Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
