Question about Dell Studio 15 Laptop
I inserted a disc (dvd) it will not eject. any
I inserted a disc (dvd) it will not eject. any suggestions?
  • Dell Master
  • 3,866 Answers
If the disk will not eject but however you got full power to the dvd rom then the dvd rom will need to be removed from the laptop and then opened up to manaul eject the disk.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 30, 2009
Is there a way to get the disc out without dismantling the entire TV? Disc is stuck, lock icon shows when eject button is pressed. Can TV be reset to factory specs?
Try the following. kindly update result here in comments
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Mar 21, 2016 | Toshiba Televison & Video
Dvd wont load up.. keeps sayin no disc
The most common reason for the DVD not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your DVD plate, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your DVD including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your DVD on your TV Combo going again!
Hope this help...
Jun 05, 2010 | Televison & Video
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Dvd drive wont eject the dvd.
find a thin stick but must be verry thin.  you will see a small hole in DVD uniit.  put the stick in it your dvd will eject.
May 29, 2009 | Dell Studio XPS 16 Notebook
Advent DVD player in car won't eject DVD
Get hemastats or a thin pair of tweezers and have at it.
Mar 12, 2009 | Sony MV-900SDS Car DVD Player
Panasonic dvd recorder model dmr-e55eb/ebl. played dvd,no problem - ejected dvd - green/blue colouring appeared on TV which disappeared when dvd recorder switched off. since then unable to play dvds. ...
This is a problem with either the logic or the power supply. Without seeing the machine and taking measurements inside, I can't state for sure the exact problem. These are decent machines. I would suggest that you bring it to an authorized Panasonic service center for a repair estimate. Post the results here and we'll suggest the next steps.
Dan
Apr 23, 2008 | Televison & Video
DVD will not come out
Believe it or not, unplug the power from the wall for at least 60 seconds. Then plug back in and power up the unit and eject the DVD. Sometimes you need to do this 3 times before it works. My complaint is that I need to do this for 95% of the DVD's I insert and then try to eject. This is clearly a manufacturer's defect...
Feb 17, 2008 | Toshiba 19HLV87 19 in. LCD HDTV
Disc won't eject
Hi, to open thje the disc tray , look for a tooth pick , insert small hole in front panel push and back until disc tray out. , motor belt need to replace.
Jan 19, 2008 | Teac (DW-224E) DVD Drive
Xdvd8181 not accepting any discs
Check this.
http://www.fixya.com/support/t892341-cd_wont_stay_in
Sep 13, 2007 | Dual XDVD8170 Car DVD Player
Dell Studio 15 Laptop Logo
300 people viewed this question
Alun Cox
