Question about Sansui VRDVD4005 DVD Player/VCR
How do I record information from VHS tape to dvd on model vrdvd4005
  • Sansui Master
  • 520 Answers
I believe the VRDVD4005 manual is available on a Sears sponsered website called managemylife.com. I hope this helps you. Look under "Dubbing".
Posted on May 18, 2010
Can I record DVDs from a Sharp 13VT-N100? The only connection source is the coaxial antennae port. There are "In" sources so I can watch DVDs from a DVD player but how can I reverse that so I...
Recorded from tv shows to DVD Disc have to hookup AV RCA component cables to both to Tv and DVD recordable player model connections together.Yes,u will able to recordable VHS tapes to DVD Discs.But ur DVD player model u have it is must be a recorderable DVD player model?Not just a DVD Discs and VHS tapes player only model.Check ur owner manual all are in there.
Aug 20, 2011 | Sharp 13VT-N100 Combo
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
I have a sansui combo VRDVD4005 I need instructions on how to copy my VHS tapes to DVD format.
I believe it's available on a Sears sponsered website called managemylife.com. I hope this helps you. Look under "Dubbing".
Apr 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
SANSUI WAY TO RECORD FROM VCR TO DVD
Your model is a DVD player only and has no recording capability. There are devices that will allow you to transfer your VHS tapes to a computer equipped with a CD/DVD writer to preserve them on disk.
Tevion is one make that comes to mind.
Feb 15, 2010 | Sansui VRDVD4005 DVD Player/VCR
Have a Sansui VCR/DVD player/recorder. I'm trying to record a VHS to a DVD. Lost the manual. Can you walk me throuh it?
Google the term "Sansui/the model number/manual." A lot of hits will come back, likely a number will have a free downloadable copy of the owners manual.
Jan 28, 2010 | Sansui VRDVD4005 DVD Player/VCR
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
Transferring a VHS tape to DVD.
First - be sure you have a DVD RECorder unit and just not a playback unit- It must say recorder on the unit and your manual --
You need DVD-R dvds only to put into this unit.
The instructions are involved and include 5 steps--
1. Format the empty disc.-done automatically when you put any empty disc into the unit.press yes
2. Put on VHS mode on -remote-light VHS lights up on unit
3. Press Dubbing on the remote and press yes
4. When finished press stop on the remote- wait
5. Finalize the DVD- this must be done p. 27 and 28 in manual or see info in my other solutions.
All this process is in the manual on page.76
Have fun DD
Mar 16, 2008 | Sansui VRDVD4005 DVD Player/VCR
Sansui vhs/dvd
there is a detection switch in the back of the unit it need to be cleaned or replaced.
Dec 13, 2007 | Sansui VRDVD4005 DVD Player/VCR
Transfering vhs to dvd
Is the vhs tape copy protected? I think you can only copy your own vhs tapes or what you record on tv. I could be wrong though.
Dec 03, 2007 | Sansui VRDVD4005 DVD Player/VCR
Vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Oct 09, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD4005 DVD Player/VCR Logo
153 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
