Question about Gateway Wireless-B Router (wbr-100)
Please help! Been trying since Saturday to connect router!
Please help! Been trying since Saturday to connect new Linksys router to pc. Tried setup wizard that it came with, tried typing in ip address 192.168.1.1 and am getting an at&t error message and web results that don't help, I cannot access the web based site, I've used cmd with ipconfig/all, ipconfig/release, ipconfig everything! I've pinged the router with no success, I tried the cat 5 cable connected directly to pc, I've deleted browsing history and deleted cookies! Is it possible that At&t or Internet Explorer is set up automatically to something that is causing it not to recognize the router? Please help asap, we're going insane!!
  • cashmommy99 Jun 30, 2009
    Thank you for your help! I still am not getting any joy! I have a Linksys Etherfast Cable/DSL router with 4 port switch (Model No. BEFSR41) I've called Linksys and they told me that it could possibly be my web browser or internet that's causing the problem, whenever I type in the ip address it gives me an error message and shows me web results, it will not let me enter any ip addresses and go directly to them. I'm not sure how to obtain a DHCP automatically or how to do a DHCP renew, I'm not very computer savvy, I've gone into all of the computer menus to try with no results, I've even tried a search from my computer!! Thanks for your suggestions, I'm sure if I knew what I was doing they would probably have worked!! Thanks again!
    Problem Solver:
  • 9 Answers
You must start configuration with the router directly connected to the PC. You should factory reset the router, usually this means pushing the reset button for more than 10 seconds, check your manual, it may also mean that you need a paper clip and push an internal button. Once the linksys is reset; follow the setup guide which is typically connect the PC to the router. Reboot the PC, insert the CD ROM setup software (some times they do not want you to connect the router before you run setup, check the instructions again). Then you should go through the wizard. If that does not work, go to the linksys site and make sure that the router adress is 192.168.1.1 it could be different. Make sure you understand the address format is x.x.x.x in the browser it MUST BE TYPED http://192.168.1.1 enter; sometimes internet explorer has problems with IP addresses; firefox is better. You must know the default username and password. BTW, ALWAYS POST THE MODEL NUMBER TO GET HELP!
Posted on Jun 30, 2009
  • 2,460 Answers
Put the setup CD in a drawer. Set your computer to Obtain a DHCP automatically. Plug in the router to the AC outlet. Plug the computer into any of the LAN ports of the router. Start the computer or do a DHCP renew. Now do an IPCONFIG. Do you have a 192.168.1.x address? Go to IE and use 192.168.1.1 in the address bar. Do you get the login screen? The username is left blamk, the password is "admin". Are you there?
Now, just because I put the cart before the horse, are you possibly using one of those 2wire or Netopia DSL routers? Is it possible that the IP address for it is 192.168.1.254 or worse, 1.1?
Bzzt. Give your router a neat address like 192.168.1.251 and turn off DHCP. Now, plug the WAN port into the modem. and point your browser to 192.168.1.251. Whoa! Did I guess right?
Let me know.
Carl
  • Carl Navarro
    Carl Navarro Jul 02, 2009
    Ahh, To the left of your space bar is a Windows symbol. Press it, and while holding it down press R. It will pop up a box that says RUN and a box that says Open. In that box type cmd and click on OK. Wow! Check it out. You have now entered DOS!
    From the > prompt, type IPCONFIG and press ENTER.
    It will spit out a whole bunch of numbers. You are concerned with only 2 sets, the ones after IP Address and Default Gateway.
    Mine says 192.168.1.111 and 192.168.1.1 :-)
    If the first 3 octets DO NOT MATCH (ie 192.168.x) you are never getting to the router. If they do, the type the address of the gateway in the for 192.168.1.1 or 0.1 or 1.254 or 10.0.0.1 or whatever the address of the gateway is into Internet Explorer.
    If for some silly reason you DO NOT MATCH the first 3 octets as above, post back and I'll give you lesson number 2 where you actually check the Network Card.
    cn
I cant put safety as
Are you trying to secure the wireless network?
For this you will need to access the router setup page and change the settings manually.
See how to secure wireless network.
If you are not able to save the settings then I will suggest you to upgrade the firmware of your router. The reset the Linksys router and reconfigure it manually.
Create a new wireless network. Change the name of the wireless network that you never used before.
Then try to connect to the new wireless network.
See How to reset Linksys router.
See Linksys router setup
Jan 22, 2012 | Linksys Wireless-G WRT54G Router
It was working fine until ive reset my linksys wrt54g, and i did my setup again, but i dont get any internet connection, my linksys is using a cable to my pc. please help
When you resetted your linksys router, chances are, the setup for WAN connection was lost. You can try these steps:
1. Connect the internet directly to your pc. If your pc was able to browse the internet, move on to the next step. If not, you'll have to contact your ISP for the settings of your internet connectivity.
2. Connect back the internet to the WAN port of the router, and connect your pc to the router's LAN port.
3. Open the router's page in a browser (the address usually is 192.168.1.1, username is admin and password is admin)
4. If your router has a setup wizard, run the setup wizard, because it usually clones your pc's mac address.
Hope this helps.
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
Linksys wrt160n router. wireless xbox won't connect
I made it an unsecured connection and everything worked. Not ideal solution, but it worked.
Feb 07, 2010 | Linksys WRT160N Wireless Router
Linksys switch to new pc
Have you tried going to the Linksys Forums and asking this question, I had similar issues when we moved house and the guys over there were most helpful.
Jan 28, 2009 | Linksys Wireless-G WRT54G Router
Setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
No CD need to set up Linksys Wireless G Router
Router setup
You do not have to use the cd. Follow these instructions:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 15, 2008 | Linksys Wireless-G WRT54GS Router...
Connect a new linksys router to my laptop
If you purchased a new router from Linksys, they should have provided you with a CD that provides step by step instructions, with video on how to setup your router. If your bought your router used, then you can still utilize Linksys web site support to assist you. Please follow this link, and click on EasyLink Connect. This will download a small program that can help you set up your router.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US%2FLayout&cid=1166859678292&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7829237314L11
Sep 23, 2008 | Computers & Internet
Gateway Wireless-B Router (wbr-100) Logo
117 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
