Question about HP Photosmart R707 Digital Camera
HP photosmart R707 camera does not turn on and charge
I was trying to take one picture with a low battery charge when i pressed the button it suddenky turned off, when i tried to charge it a red led turned on for a few seconds and the turned off. the green led that is supposed to indicate charging never turned on, and a strange noise came from the inside. when i left the camera charging for about an hour, hoping the green light could turn on, I touched it and it was hot.
please help me solve this problem
  • 2 more comments
  • angel71 Nov 30, 2007
    I'm having the same problem my camera does not seem to want to charge.
  • queeniejeep Dec 04, 2007
    same thing here... just looked at some other postings & there is an update for firmware on - but you have to get the camera to turn ON! Mine will charge a little but I have to play with the connection for quite a while to get it to take - then I have to disconnect it some time soon because the camera gets VERY hot! THEN I have to play with it over & over to get it to turn on... some days it will - others it won't - guess it depends on how patient you are... I really want to get mine back ON so I can see if the firmware upgrade fixes it! Does anyone know? Otherwise I will post as a solution if I get it to work... I really hope it does... I love this camera!
  • phlorah Dec 26, 2007
    My HP R707 will not turn on. I can try with a battery or with the power cord, but nothing happens. Following the "reset" procedure does not fix the problem. A red light next to the viewfinder comes on for a few seconds, but nothing else happens. It's the same red light that indicates when a video is recording.
  • Anonymous Sep 05, 2008
    Camera won't turn on or charge. I can only get a flicker of red light??
I Recomend you to charge your camera before it reaches the lowest level of charge displayed in the LCD Screen This might help the camera to turn on again after long usage but this is something you must take in consideration before it gets ruin but if it is already ruined and you have good luck you might be able to turn it on again and then you shall follow my advise.
Posted on Jan 04, 2008
If you want to turn it on do a firmware reset:
To do a firmware reset, open the battery bay, remove the battery and the SD card, and then insert a paper clip into the tiny hole in front of the little "+ -" sticker on the battery door. Hold it for 6 seconds, and remove. After this reinsert the battery, and the turned it on this should allow you to do the update
Posted on Dec 25, 2007
  • wajid rafiq Jan 23, 2013
    apply firmware reset but problam no solved only red led on
Continous "charging flash" when trying to snap a picture
Connect the camera to the charger and take the picture. If the charging flash stops after a couple of seconds, it means that you need a new battery.
Jan 08, 2010 | HP Photosmart R707 Digital Camera
Hp 537 photosmart camera. my picture is frozen. i can,t access my previous pictures nor take any other picture. camera will flash but no new pictre is shown. please help.
Try to reset the camera - take out the battery then push the reset button with a straightened end of a paper clip. Hold the reset switch depressed for about 3 seconds. Reinsert the battery.
Sep 28, 2009 | HP Photosmart R707 Digital Camera
Battery is fully charged but when I push button to take a
Camera takes pictures with flash off. With flash on message comes up and says flash charging and camera freezes unable to turn off I have to take the battery out
Jul 12, 2009 | HP Photosmart R707 Digital Camera
No power after dropping it accidentally...
try pushing the reset button by the battery slot, use a paper clip and hold for 5 seconds without the battery in it. good luck
May 10, 2009 | HP Photosmart R707 Digital Camera
HP R707 wont take pictures - get F2.8 1/60 message
Does it work while connected to charger? If yes, you need a new battery.
Feb 04, 2009 | HP Photosmart R707 Digital Camera
I have an hp r707 it wont charge or turn on at all it light red where the record button is but thats it what can it be
Try to connect it to the charger. If it works while connected to charger, you need to replace the battery.
Jan 02, 2009 | HP Photosmart R707 Digital Camera
Hp r707 wont turn on
Connect the charger. If the camera works while connected to the charger, you need a new battery.
HP R707
get the adapter plug it in,, in the camera that little hole next to the usb,,, just like u will charge the battery, then turn the camera on,, just your camera lens will be back to normal,, hope i helped ya out.
Sep 11, 2008 | HP Photosmart R707 Digital Camera
HP Photosmart R707 Digital Camera Logo
654 people viewed this question
Top HP Cameras Experts
Fred Sops
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
