Question about Asko W6441 Front Load Washer
Hi, I have an F1=a fault in the water supply on my ASKO 20605. What are the possible solutions?
    Sergeant:
    Champion:
  • 353 Answers
Usually water valve faulty
Posted on Jun 30, 2009
Unit has been flashing F1 and now doesn't seem to complete the cycle. Just keeps running.
The F1 error codes is a water heat fault,the control has determined that within 60 minutes that the correct water temp.has not been reached
The possible causes of that are
A burnt out heat element
A burnt out thermostat
Gene
Aug 22, 2011 | Asko 24 in. 1895 Built-in Dishwasher
Asko w6 222 has a F1 error. how do I fix it. thanks Rose
Hello Rose, here is a chart to help you identify what the problem is with your asko
Failure
Code
Condition Check/Repair F1 Water supply/low water fill · Check water supply to machine
·Replace water inlet valve F2 Water level too high · Plugged/Bad water pump
· Faulty water valve F3 Pump problem Check pump trap and clean. F4 Thermistor problem · Open thermistor, replace
· Bad wiring to thermistor F5 Fault in thermal cutout or heating pause fault. Selected temperature not reached in 90 minutes · Check heating element
· Check thermostat F6 Motor fault · Check wiring to motor
· Replace motor if necessary F7 Door lock release fault · Bent pull-rod for door latch
· Bad door latch solenoid 00 00 Machine did not spin Check load for out of balance Redistribute load and restart
usually this means the water valve that the hoses are connecting into the machine has gone bad and needs to be replaced if your looking to order the part online i would suggest marcone appliance parts they seem to be the cheapest when it comes to repair parts and they are also one of the biggest I hope this opinion has helped in your appliacne situation and if i can answer any further questions please message me back. Please also remember to rank how this opinion has helped in your appliance situation
Thanks again
Rick
Nov 28, 2010 | Washing Machines
Asko 20605 washer stopped mid-cycle, now no power?!
The ECU should be tested. Look for the service manual inside the chassis for troubleshooting procedures.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 04, 2010 | Asko Washing Machines
Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
Check the fault code status :
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
F1 means Water supply/low water fill .
Thanks
Mar 02, 2010 | Washing Machines
F1 error code -wont advance after it hits wash cycle--heater ohms out ok-any solutions?
F1 Water heating fault, selected temperature not reached within 60 minutes · Incoming water temperature too cool
· Heating element burned out
· Thermostat defective
Feb 02, 2010 | Asko D1776 Built-in Dishwasher
Asko washer 20004 stopped mid cycle, water is
Do not play with water and 240volts or 120 volts....it is a LETHAL cocktail.
Get a techo to save you the headache and possibly YOUR LIFE!
Oct 19, 2009 | Washing Machines
Model 20605; problem, F-3 fault in pumping out
Usually cleaning out the pump will correct the problem.
Oct 06, 2009 | Asko Washing Machines
F6 CODE
F6 on an asko washer means a fault was detected with the motor. What this means 99% of the time is the brushes in the motor are worn. As long as the armature isn't damaged, (visual inspection while turning motor shaft should identify damage) you'll be fine replacing the brushes.
part # 764414, 2 required, about $40US each (better than $400US plus for a motor).
hope that helps
good luck
May 30, 2008 | Asko W6021 Front Load Washer
Motor Fault
check the carbon brushes on the motor or it can be a motor fault also change the belt at the same time
Apr 25, 2008 | Asko W6021 Front Load Washer
Dishwasher fault
I got this with another dishwasher. On that one it meant the water wasn't feeding into it (tap switched off, kink in inlet tube, etc.)
Feb 16, 2007 | Asko 24 in. D3120 Dishwasher
Asko W6441 Front Load Washer Logo
304 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
