Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9150PW0 Whirlpool Duet washer will not spin F02 and Sud
I get Sud and 4 minutes later I get FO2. The system drains completetly but doesn't go into spin. Installed new pump. Removed and cleaned all drain hose's from tub to pump to wall drain.Still get same error message. I have ran the Diagnostis on the CCU and the pump will run continusly from C:06 through C:08 It will spin at the fastest speed at C:08 so it is capable of spining but just will not do it on a normal wash.I also replaced the pressure switch. Nothing helps. The new pump acts the same as old pump.
Please Help
Jerry
  • 12 more comments
  • cable_rd Jun 30, 2009
    Do you mean door switch versus lid switch since this is a front loader. And is the door switch the problem or may be the problem.
    Jerry
    Checked the door switch and it openes and closes as it should.
    Jerry
    I get Sud and 4 minutes later I get FO2. The system drains completetly but doesn't go into spin. Installed new pump. Removed and cleaned all drain hose's from tub to pump to wall drain.Still get same error message. I have ran the Diagnostis on the CCU all funtions worked except the pump will run continusly from C:06 through C:08 It will spin at the fastest speed at C:08 so it is capable of spining but just will not do it on a normal wash.I also replaced the pressure switch. Nothing helps. The new pump acts the same as old pump. I have checked all connections on CCU AND MC UNIT.
    Please Help
    Jerry
    It seems I did not make myself clear. Or you did not read my post past the F02 and the Sud.
    I have did the following things trying to fix this unit.
    Cleaned pump several times and there was nothing in it from the begining it was clean each time.
    So the diagnostics that came with the unit said if pump runs longer than 8 minutes replace pump.
    So I replaced the pump with a new assy. This did not help.
    So I replaced the pressure switch, that did not help.
    Also after I ran 40 or so rinse and spin cycles that did not complete. I removed the pump and all hoses and cleaned everything, that did not help.
    Before doing any of this I removed each connector from the CCU and MC, that did not help.
    Jerry
    A wet dry vaccum cleaner works far better for that than sponges. It is quick and no mess period.
    Jerry
    Please Help
    Jerry
    I said their was nothing in the pump it was clean all hoses was clean. I even put on a new pump. What gives with these answers that I am getting. Doesn't these experts read what I have posted.
    cable_rd
    Cabe_rd
    This is all standard processes that came with my machine, I have did that plus all the other things that I listed. So please go a little futher than the common since items.
    cable_rd
    This is a Front Loader not a top Loader. No drive couplin on a front loader.
    Thanks for your input.
    Cable_rd
    MnFisherman, I have new pump, new pressure switch, but I do not have a new latch. The latch works perfectly no problem. If I have a sensor problem what is that sensor called and where is it located.
    cable_rd
  • cable_rd Jul 01, 2009
    President:
  • 942 Answers
Just try to reset your unit by unpluging for 5 hour's the porpuse for this is to drain the stored current in the memory
Regard's
Nice
Posted on Jul 01, 2009
  • 11,896 Answers
There is a sensor that relays information back to control board. If you have new pump, pressure switch and latch, the sensor is most likely faulty
Posted on Jun 30, 2009
  • Nate Stansfield
    Nate Stansfield Jun 30, 2009
    Such an error can also be caused if using the wrong detergent which can
    create sudsing. Only HE detergent should be used and usually only about
    2 tablespoons, 1/4 cup at the very most.
    Press PAUSE/CANCEL twice to clear the display. If the error repeats:
    After looking up the F02 error code, I understand that this machine may not have the sensor.
    Top Expert:
  • Whirlpool Master
  • 79,865 Answers
Has the drive coupler been replaced to the tub?
  • 136 Answers
"SUD" (Suds Routine)
When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displaed during rinsing at the end of the cycle to inform you that Suds Routine was activated. To avoid excessive sudsing reduce HE detergent amounts.
"FO2" (Drain Problem)
select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
    President:
  • 1,734 Answers
Sounds like its possible with all the items thats been found in the water pump filter, it could have damaged the pump impeller. A new water pump may fix it up for you now.
Part#285998 (http://www.repairclinic.com/referral.asp?R=1265&N=1094146)
The filter is under the washer door. You take off the bottom panel under the door and you will see this white knob that screws off. Just make sure the washer has drained if not you will have a flood.
    President:
  • 987 Answers
Tip 1: If you don't own box wrenches, a couple of wood paint stir sticks work just as well.
Tip 2: You don't need a lot of towels if you're clever and patient when you remove the drain trap cover. Place two large sponges (like what you use to clean your car with) on either side of the drain trap cover and only unscrew the cover enough to let water out until the sponges are full, then screw the cover back on, wringe out the sponges into a bucket next to you and repeat until all the water has been drained out. This takes time, but saves the trouble of cleaning up half a gallon of water that would otherwise be flooding the floor of your laundry room.
I had to go one step further because of where the fabric was jammed in the impellor (water pump). If you can't remove the material that's jamming the impellor by reaching in with your fingers, you may need to remove the pump/impellor for easier access to the material. To do this, unscrew the three phillips head screws that secure the gray, plastic flange to the white drain trap. One is on the hidden "back" of the gray flange, but you can easily find it by feeling around with your fingers. When you remove the impellor/pump, keep track of the black, rubber "washer" that may fall off the impellor. You can now get at any foreign material stuck in the impellor. Once the area is cleared, put the rubber washer back on the pump, and put the screws into the holes of the gray flange before positioning the pump on the drain trap. Tighten the screws until they stop, but don't overtighten because you're only screwing into plastic. Now you can finish putting the drain trap cover back on, remove the clamp and restore the bottom front panel.
    Sergeant:
  • 175 Answers
Hi..the reason to this problem is the lid switch.
It might be faulty.
check this out..
thank u..
kindly rate my response..
Received a SUD error
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Whirlpool Fault Codes
Aug 26, 2014 | Washing Machines
Water will not drain the fo2 code is on which I know it means its clogged but how do I get it unclogged?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why does my whilpool duet washer flash F2: Its holding water and beeping.
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F2 error code
Hello there
F/02 Long Drain
Nov 19, 2010 | Whirlpool Washing Machines
My washer is displaying an "F02" message. What does this mean?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayedfc2323f.jpg3830f06.jpg 600f261.jpg
Your tech sheet? GHW9150PW0 Tech Sheet # 8182277 Rev #
Duet service manual and codes
Rate it or hate it:
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite HE3 front load washer won't drain or spin and displays sud and flashes FO2
Hi there
I have found this and i hope this gets you in the right direction. Merry X-mas and Happy New Year also.
Sud SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Thank you for writing to Fix Ya.
Best regards Richard
Dec 15, 2009 | Washing Machines
Washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
Potential Causes
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenomore Elite HE4t Washer. I am getting an F02 error message. I've tried to rerun washer & get SUDS on and off. Fo2 message appears again and cycle shuts down. Door will not unlock. Any...
Potential Causes
Oct 14, 2009 | Kenmore Elite HE4 Electric Dryer
Whrilpool duet front loader washer flashes f2
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
801 people viewed this question
Dan Webster
Dan Webster
Sal De
