Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
Need program code for the refrigerator there is
Need program code for the refrigerator there is not a unit serial plate. Model # MFI2568AEB
  • 999 Answers
Look under the toe plate for the tech sheet. If it is missing the part number is 16026830
eric
Posted on Jun 30, 2009
I am talking abt maytag refrigerator . New board panel and the PE0000 just keeps flashing
You need to program the new board. Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word Code.
1. Press and hold the Door Alarm Keypad .
2. Press and hold Freezer Temperature Down Keypad .
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the Freezer Temperature Down Keypad once more.
6. The control will display the current Program CODE. This value should be validated with the
Program CODE printed on the unit serial plate.
NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature Up Keypad or Refrigerator Down Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature Up Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated.
The Programming mode can be exited at any time
Oct 13, 2016 | Maytag Refrigerators
I have replace the front panel of my kithchenaid fridge model KFIS25XVMS9 code 1813 but it doesn't work.
It is easy to make a mistake in the instructions below so pay close attention to the instructions or they will not work until you do.
Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word "Code."
2. Press and hold Freezer Temperature Down Keypad within 3 seconds .
6. The control will display the current Program CODE. This value should be validated with the Program CODE printed on the unit serial plate. NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature Down Keypad until the Program CODE begins flashing indicating it has been saved. NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).
Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated. The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes.
Aug 26, 2016 | KitchenAid Refrigerators
How to check for a bad sensor on my MFI2569YEWO maytag fridge? We've replaced the control board in the back and display board in the door. the display reads PE0 000. Can't get it to program. HELP ME!
Patti when you change the main control board you have to reprogram the refrigerator to understand the board there is a code just below the model number and here are the instructions you need to follow them carefully
Programming Mode:
http://www.appliance911seabreeze.com/
Aug 09, 2016 | Maytag Refrigerators
Able to entry program code printed on serial plate, unit does not save it. display does not blink the entered code.
You have the wrong board! order by model and series number to get the correct board. This is very tricky because many models do not have a series number so you have to know the serial number to get the correct part. Usually the first two of the serial number.
May 22, 2015 | Refrigerators
I am in need of the proper programming sequence to enter the defrost cycle on a Maytag F/F model MFF2558VEM. The factory tech sheet is not on the unit
Lakeland Appliance: According to FixYa.com Jenny Dutot said: "Dear jorge, I had the same problem when my refrigerator was broken. You need to re-program the control panel as follows: 1. First you need the Program Code for your fridge. It is on the plate on the inside of your fridge, on the same plate that has your Model # and Serial # on it. 2. Programming is done with the refrigerator doors open. 3. Press and hold the Door Alarm keypad on the control panel. 4. Then press and hold the Freezer Temperature Down keypad. 5. Then release the Door Alarm keypad and wait 3 seconds. 6. The control pad will then display PE to indicate it's in programming mode. 7. Entry is confirmed by pressing the Freezer Temperature down keypad once more. 8. The control panel will display the current program code. It should be the same one that I asked you to find in Step 1. 9. If the program code is the correct one, exit the programming mode by closing the refrigerator doors. 10. If the program code is not the correct one for your refrigerator, press the Refrigerator Temperature Up or Down to change the value with each keypress. 11. The decimal point indicates the selected digit. Press the Freezer Temperature Up or Down to select the next digit. 12. Once the desired program code is displayed, press and hold the Freezer Temperature down keypad until the program code begins flashing, indicating that it's been saved. 13. Again, when you're done, exiting the program mode is done by closing the refrigerator doors. Hope this helps alot of people out there. I'm not sure what the problem is at Maytag, but they're extremely slow in getting parts shipped for their units. The local Maytag repair people have indicated to me that they are seeing an overwhelming number of Maytag refrigerators needing repairs that are around the one year age range. They say the quality of the new units is terrible. "
Apr 15, 2015 | Maytag Refrigerators
Replaced circuit board, refrigerator wont allow programming, just says PE0 000
Dear joe, I had the same problem when my refrigerator was broken. You need to re-program the control panel as follows: 1. First you need the Program Code for your fridge. It is on the plate on the inside of your fridge, on the same plate that has your Model # and Serial # on it. 2. Programming is done with the refrigerator doors open. 3. Press and hold the Door Alarm keypad on the control panel. 4. Then press and hold the Freezer Temperature Down keypad. 5. Then release the Door Alarm keypad and wait 3 seconds. 6. The control pad will then display PE to indicate it's in programming mode. 7. Entry is confirmed by pressing the Freezer Temperature down keypad once more. 8. The control panel will display the current program code. It should be the same one that I asked you to find in Step 1. 9. If the program code is the correct one, exit the programming mode by closing the refrigerator doors. 10. If the program code is not the correct one for your refrigerator, press the Refrigerator Temperature Up or Down to change the value with each keypress. 11. The decimal point indicates the selected digit. Press the Freezer Temperature Up or Down to select the next digit. 12. Once the desired program code is displayed, press and hold the Freezer Temperature down keypad until the program code begins flashing, indicating that it's been saved. 13. Again, when you're done, exiting the program mode is done by closing the refrigerator doors. Hope this helps alot of people out there. I'm not sure what the problem is at Maytag, but they're extremely slow in getting parts shipped for their units. The local Maytag repair people have indicated to me that they are seeing an overwhelming number of Maytag refrigerators needing repairs that are around the one year age range. They say the quality of the new units is terrible.
Apr 21, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Programming hv board
I have the same Maytage MFI2568AEB on the inside top left of the refrigerator the code is 0302, i still cannot enter the code, showing PEO OOO.
Jan 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
MFI2568AEB HV Programming code
I have recently gone through same problem . The cose that was installed in the new control card for MFI2568AEW was 1411.
Mar 25, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
How do i reprogram my HV board?
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 SECS.-4.CONTROL WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Oct 26, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
297 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
