Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Release brake engine dies engage blades engine dies
Replaced brake switch. replaced seat switch but seat switch doesnt do anything
  • 127 Answers
There is a saftey switch on the deck that has shorted out need to replace
Posted on Jun 30, 2009
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Engine dies when brake is released.
You have a problem with a safety interlock. I'm betting it's the operator presence safety seat switch. To check if it is the seat switch:
  1. Unplug the seat switch.
  2. Jumper the seat switch wiring harness plug receptacles.
  3. Start your tractor & release the brake. If the tractor stays running, replace the seat switch.
Sep 25, 2013 | John Deere 26HP Hydrostatic 54" Riding...
My 2001 cadillac sls traction control light goes on and off and when i apply my brakes the light on trunk lights up but the back brake on left and right side of car dont light up, when I use keyless
GM have a know problem with the Brake Switch on the Pedal, When the Cyclopes works and the other Brake Lights do not...
You need to replace your Brake Switch
Apr 08, 2013 | 2001 Cadillac Seville SLS
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
My 1997 blazer all three brake lights wont work ,checked the fuses all good .parking lights and turn singnals work fine .when i push the brake pedal you hear a noise comeing down from the pedal. please...
There is a switch on the back side of the brake pedal that turns on the brake lights (it looks like a button) when you press the pedal, I would start by finding that switch, pressing it by hand and seeing if anything happens. If that doesnt work then the switch probably needs to be replaced.
If you have a multimeter you can remove the switch and test it to see if its working.
With the switch not pressed, check the resistance between the two leads, it should read infinity.
When you press the switch the resistance should drop to zero.
Anything else suggests a faulty switch, which you should be able to get at your local auto parts store.
Jun 07, 2011 | Chevrolet Blazer Cars & Trucks
When turning the ignition switch on my LT 1000 craftsman tractor, it doesnt do anything. I have replaced the battery fuse and the ignition switch and nothing happens. The lights doesnt come on either. It...
You may either need a seat switch,pto switch or a park break switch.If the tracter is in nuetral with the park break set,it should start with out anyone on the seat,eliminating the seat switch.If you on the seat and the park brake is pushed and it wont start make sure the pto is off,if it is and nothing happens,then it's likely the parkbrake switch.Also check the connections on the battery,starter and engine block[ground].Let me know how you make out.
Mar 17, 2011 | Craftsman Garden
Brake lights don't work
You'll need to check the brake light switch with a multimeter. Meters are fairly cheap ($5 to $10) and can be bought at any home improvement store, Radio Shack, auto parts stores etc. Move the driver seat all the way back, look near the top of the brake pedal with a flashlight.
There will be a switch attached near the brake pedal support, disconnect it. Then test between the leads on the switch itself with the multimeter set on ohms or continuity. While holding these in place, activate the switch either at the switch or with the brake pedal.
The switch should read very low or no resistance when it's activated (closed). In it's normal (rest) position, it should read extremely high or infinite resistance. Anything else and it's likely shot - replace it.
Dec 04, 2010 | 1985 Ford Econoline
Every time I lift off the seat of my John Deere engine Dies....
The seat switch is doing it's job,you can;t get off the seat unless the pta is off and the tractor has the park brake engaged.Replacing the switch won't change anything.
May 16, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Scotts 1642 riding mower take foot off brake engine shuts off
Sounds like the safety switch in the seat is bad or disconnected. Look under seat to see if anything is unplugged.
Nov 05, 2009 | Briggs & Stratton Garden
97 chevy truck 1500 gear shift gets stuck in park
You can remove the interlock off the gear shift or maybe spray some crc on it otherwise probably a loose wire or switch
Jul 09, 2009 | 1999 Chevrolet S-10 Pickup
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
347 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
