Question about Gateway Wireless-B Router (wbr-100)
How Can I Get My Network's Port Number?
I've tried to find it on my laptop, but I just cant find it if you find a solution that would help.
    Genius:
  • 1,269 Answers
Can you tell us what the main problem is?
Posted on Jun 30, 2009
My DHCP is not assigning a dynamic address to one of my seven wired devices. I've had to switch over to a stati
On the second router just plug a port cable in from your main routers port into the wan port and then be sure to change the second routers gateway and IP address to a different number. Say that your main router IP is 198.18.1.1 and for your second router IP you could use 10.10.10.1 or what ever combo you want and then you should be able to use both routers together. Is this what you are trying to do?
Linksys routers as well as all routers with DHCP enabled should be able to handle up to 255 separate IP address's for a LAN network. Is the firmware of the Linksys the latest? If not, down load the latest firmware and flash the router to update it. Or, check out third party firmwares like Tomato to flash that tired Linksys and turn it into a real router.
Apr 14, 2017 | Actiontec Verizon Fios Mi424wr Modem...
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Jul 03, 2012 | Samsung VP-D77i Mini DV Digital Camcorder
Does this notebook have a fax modem
Which notebook? You didn't give us a brand and model number.
Look on the sides and see if it has a port that will accept a telephone cord. If so, that's the modem port. Don't get it confused with the Network Cable port. The network cable port will be larger, but they both look the same. In fact if you tried to put the network cable into the modem port, it won't fit because the network cable is bigger than the telephone cord.
May 15, 2012 | Computers & Internet
I cannot connect to the WIFI at work, but I can connect to my WIFI network at home, and other public networks. The wireless network at work is pushed by a D-Link 8200AP with a WAP security, just like it is...
Your laptop cannot connect to your work's wireless network because the security settings (ir WAP) in the D-Link is different to the security setting in your Netgear.
The wireless card in your laptop will need the settings changed to suit the D-Link's wireless settings ie the SSID and WAP.
You will need to change the wireless card settings in your laptop back to the Netgear's wireless settings to connect to your wireless network at home.
Some wireless cards allow you to set up different profiles for different wireless networks which allow you to switch wireless networks easily by just selecting the profile for the network you want to connect to.
Jun 25, 2011 | Apple iBook G3 Mac Notebook
I have an HP Laserjet P2035N that worked just fine until I moved it from home to my office. When I hooked it up to my laptop, which it has been before, it said the printer was offline. I've tried...
network printer is connected to check network connection. (cable, plug, etc.), if everything is ok not a problem to the network printer port on ferl can happen and if it is installed USB port, possibly connected to a another USB port
May 25, 2011 | HP P2035N LaserJet Monochrome Printer
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
I cant install my wireless router. i moved and
we ll start with the physical connections.
1.take ethernet cable n connect one end of the cable to the modem and the other end to the isolated port on the router(internet port) and then connect the computer and your router with other cable(any lan port).refer the chart on the router to distinguish the internet and lan port.
2.check the light status on the modem and router.
router lite status-power,alphabet i lite,wireless lite(lollipop lite) and the number light lit up(depends on the port eg port no:1 connected number 1 light lit up).
3.check the ip address and default gateway address.
steps:In windows(xp,2000 etc),click on start->click on run->in the search tab type cmd->dos prompt window opens,type ipconfig and u ll get ip address and default gateway address(192.168.1.1 or 192.168.0.1).note it
In vista,start->in the search tab type cmd->dos prompt window type ipconfig->u ll get the address as specified earlier.
4.open the browser,type the default gateway address in the address bar and press enter.The login window ll ask for username and password. username-admin
password-password.
5.You ll enter the netgear smart wizard page.Run the setup wizard at the left side (blue screen).select yes and detect the type of connection.
6.If it is a cable modem-dynamic ip detected and click next.check whether the dns address is given automatically from isp and click apply.Then click on basic settings under setup menu and in that window in the router mac address select "use computer mac address "option and click on apply.Now click on router status under maintenance menu and check the ip address in internet port(it should not be 0.0.0.0) and in lan port(eg 192.168.1.2 or 192.168.0.2).
7.If its a dsl modem-the type of connection ll be detected as pppoe.click next.configure your router with the username and password provided by the isp and click on apply.The router ll save the settings and then check the internet port and lan port
address as given in the previous step.
8.Now we have to configure the router for wireless settings(both modems same configuration).
*click wireless settings under set up menu.
*In that page enter
name(ssid):netgear2
region:us
channel:11
. mode:g and b
In security options select wep and key1 give your telephone number so that you wont forget the password.CLICK APPLY.we have secured the n/w.
9.scan and connect to the network.
For windows vista-start->connect to->select the network name(netgear2)and click connect->it ll ask for password,enter it(telephone no).you ll successfully connected.Now disconnect the cable and try going online wirelessly.
For xp-start->control panel->network connections->right click on wireless network connection->select the network and configure.
10.you ll be able to go online wirelessly if there is any problem delete the preferred networks.
I have given you all the steps with examples to help you configure the router.hope you ll fix the issue and further assisstance im ready to help u but pls give details about your operating system,type of modem and no of computers so that it ll easy for me to troubleshoot.rate me if i have helped you.Thank you. Have a good day
Sep 25, 2009 | NetGear Computers & Internet
Gateway laptop w/Intel (R) Pro/100 VE Network adapter. Properties state that it's working properly but cannot connect to the network at my office. Making me nuts!!
try reinstallin the lan driver for that laptop
after that check the properties and see what it says if it still says the same then your os may have a compatibility issue with that specific driver so the hardware cant start, is this the os the laptop came with if not then its compatibility issues
if it is then your netwrk adp port may have a short or simply done good luck..
May 06, 2009 | Computers & Internet
Red Light On Wireless Adaptor For Xbox Live
just do port forwarding in the router and port number of the x box OK try it
Apr 17, 2009 | Microsoft Wireless Network Adapter Xbox...
Canon MX700 network problems
Once you have it installed and working on the USB port go to the properties page of the printer.
1) Select the "Ports" tab.
2) Select "Add Port".
3) Select "Canon BJNP Port".
4) Select "New Port".
5) Fill in the IP Address of your printer and select "Next".
Make sure that the Port is checked back in the properties page and select "Apply" and your done. Do a test print and your printer should work on your network. You may still need to fix the settings on your firewall or router to allow access if it does not print.
Sep 04, 2008 | Canon MX700 Office All-In-One InkJet...
Gateway Wireless-B Router (wbr-100) Logo
103 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
