Question about Troy Bilt Tb70ss Gas Trimmer
Replacing pull cord on 4 cycle gas trimmer, troy bilt - cord broke at full pull. Have been able to detach shaft but in order to get to cord gear must remove from main cowling. It appears the the free spin clutch that engages the shaft must be removed to remove cowl. Does this require a special gear puller? help please
  • 127 Answers
These usually are threaded counter clockwise need a pair of channel locks to hold the flywheel then with the other hand crack nut open
Posted on Jun 30, 2009
  • 774 Answers
Actually, there is special hooked tool that is exposed through the carburetor blow back vacuum line slot on the pull cord assembly. Troy Built nor Craftsman want people to know the "trick" to installing the pull cord by winding the cord spool a few notches with a new cord. (This is a $140 repair bill for them with parts.) Hold it tight with the special tool under spring pressure and refit it. Remember, the plastic cord spool engages at 90 degrees to the housing. Once you get it on, screw it in and release the tool to slide it out of the vacuum line opening. (A few have had some luck using an Allen wrench to hold the spring back until it's inserted... but this is trial and error many times to get the tension correct to retract the pull cord and it often slips off the cord spool under tension. The cord is not intended for DIY repair. Some of these models come with the option of using a portable electric drill to crank them up; its $15 at Sears... much less costly than $140 for a new pull cord + labour.
Posted on May 15, 2015
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt troubleshooting
Bushing is worn out. You will need to replace the shaft. Fairly inexpensive.
Aug 24, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt pull cord wont retract
Recoil spring is broken or slipped out of retention slot. Coil needs to be retentioned or replaced. Unless you have done this before I recommend taking to pro. This is easy job if you have the jig but almost impossible if you don't.
Jun 29, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Pull Cord Will Only Pull Out 3-4 Inches Then Sticks
Take it apart as you did before. Look for whatever it is binding. Did you rewind the rope so there is a good amount of tension? If you didn't, then do that . Good luck, Lee
Sep 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a Troy Bilt TBP6040 XP 4 cycle weed eater with the spring assist starting. The pull cord broke and I am trying to replace it but I can't seem to get the cord to go all the way back in. I need help....
I just had this same issue. I found out that you have to take the cord out of the handle then put the spool in. You then rotate the spool back in and align the spool with the spring and fish out the cord which will put a small amout of tension on it. You keep the tension on it and put the handle back on.
Rgds,
Mark J
Apr 16, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt Tb70ss Gas Trimmer Logo
1,777 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
