It's took a while to isolate the exact issue. Looks like water deposits clogged a piston inside the white attachment before the pump/motor. Be sure to clamp other side of the shaft as it will spin if you attempt to remove this. I opened it up, removed the spring loaded piston, cleaned it all thoroughly, and a dab of oil on the piston itself. It works!!
I could not find any info on the SC10 by Conair anywhere, not even their own site. I hope this helps.
BE VERY CAREFUL AS THE METAL CASTING GETS VERY HOT.
I made a video but it only allow from YouTube. I'll try to post it
