Question about Frigidaire ATF6000ES Front Load Washer
Front Load Frigidaire Won't Spin Out
Replaced control board (it gave me an E43 code, so I thought that was the problem), but it still won't spin. I can make it spin out manually (using the troubleshooting codes) - but it won't do it on it's own. It drains fine, I even drained it into a bucket just to make sure. Tumbles the load fine. ANY help appreciated!
  • thekspeers Jun 30, 2009
    I forgot to mention this is a LTF2140ES3.
  • thekspeers Jul 11, 2009
    Still having rhe same problem (ugggh). I have replaced the motor control board - that did not fix it. I then put the original back in and replaced the control board (the brain behind the knobs) - THAT didn't work either. Checked the pressure switch - seems to be working fine. I hear it click and shut off the water when it is supposed to, drains when it is supposed to, tumbles when it is supposed to, it just doesn't enter the high-speed spin mode. It WILL spin out (high speed) when I tell it to in the toubleshooting mode. Any oter possibilities?
  • 3 Answers
I had the same problem listed above on my LTF2140ES3...the machine did everything but do a final spin. In diagnostics I could do the final spin and the machine kicked out an E43 which is the control board error.
Following the advice here I changed the door latch first and the problem went away and the unit runs as it should.
You'll get "experts" who say that the unit would not spin at all if the door latch was bad. I can tell you first hand that they are wrong. Again the unit did all the normal tumbling but didn't do the high speed final spin. Again, replacing the door latch fixed the problem. The door latch is part number 131763245 (AP3886713)
Posted on Jul 21, 2009
    Sergeant:
    Champion:
  • 353 Answers
Something trapped in the pump?
Posted on Jun 30, 2009
How do I unlock the door of e43 Bosch washing machine error
E43 indicates a motor circuit error.
Lets try and reset the control board.
Switch the knob clockwise to off position. Now turn the knob clockwise to 6 O'Clock position and wait until the light starts flashing. Press and hold the spin button and while holding it turn the knob clockwise to 9 O'Clock position. Now release the spin button and switch the knob off. Tagged as: bosch
Dec 22, 2014 | Bosch Washing Machines
FTF2140ES won't spin
How old is the machine ?
if about 3years old check carbon brushers
Dec 14, 2013 | Frigidaire FTF2140ES Stacking Front Load...
Kenmore 44052 will not spin. Replaced door switch still will not spin. Ran diagnostics (code E43) so I replaced motor control board still will not spin. Could not get out of diagnostics so I replaced...
Have you pulled the pump and checked for obstructions? There may be something in the pump itself; you will need to check that...
If your problem can't solve, keep in mind that the error codes means physical wrongs, so, E43 is a door-locking problem or "board comunication problems".
I hope this helps.
Sep 30, 2010 | Kenmore 44042 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer
possible but i would look into the lock/latch assy being bad, if it doesnt think the door is closed it will not spin, nad there a re a feew different switcvhes within the latch to fail( would ve be my first choice and the part i have the most problems with)
Mar 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Wont spin at end of any cycle
I am a service technician in grants pass oregon and i had the same problem. It told me to replace the board too. I replaced the main boad, Motor control board, door switch and cleaned all the hoses and it still didnt fix it. I had 3 other service technicians look at it ( one from sears ) And nobody could figure it out.
Feb 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer won't final spin
THERE ARE A COUPLE OF CONDITIONS THAT WILL PREVENT THIS UNIT FROM SPINNING :NOT COMPLETELY DRAIN AND FAULTY DOOR LOCK AS SY.
FIRST REMOVE ELBOW ADAPTER HOSE FROM TUB TO PUMP AND MAKE SURE IS COMPLETELY CLEAN ,HOSE STRAINER THEN CHECK IMPELLER @ DRAIN PUMP NOT TO BE BROOKED , DEFORMED .DIRTY OR LOOSE IF IS LIKE THIS REPLACE PUMP IF NOT PUT EVERYTHING BACK TOGETHER ,MAKING SURE THE STRAINER IS ALL WAY DOWN (IF IT HAS ONE) IF NOT IT WILL GET LOOSE AND DAMAGE YOUR OUTHER TUB ,THEN THIS IS IT .
THEN CHECK PRESSURE SW HOSE FOR LEAKS AND BLOW SLOWLY AND CAREFULLY TO CHECK PRESSURE SW .IF CHECKS OK THEN REPLACE DOOR SW ASSY AND RUN ONE IM VERY SURE THIS WILL TAKE CARE OF YOUR SITUATION ;NOW GET ON YOUR KNEES , GET DIRTY AND HAVE A GREAT DAY!
MAYITOJHONES
Nov 09, 2008 | Frigidaire ATF6000ES Front Load Washer
No spin cycle
Before you try changing the control board, try changing the brushes of your motor.
Jun 14, 2008 | Washing Machines
417.4405200 not spinning at the end of wash cycles
Does the washer was loaded when you make the diagnnostic test ?
Jul 20, 2007 | Kenmore 44072 Front Load Washer
Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Jul 20, 2007 | Kenmore 43142 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
1,398 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
