Question about Microsoft Visual Basic 6.0 for PC
Can u help me solving my special proj using visual basic in database what good source will you recommend me pls!
  • 428 Answers
You can go to http://www.scribd.com for e-books and http://www.codeproject.com
Please, kindly rate the answer.
Wish you luck
Posted on Jun 30, 2009
What is run time error '-2147467259(80004005)' how i solved it rewati nadan
"The Microsoft Jet Database Engine cannot open the file '(unknown)'"There are several causes for this error message:
  • The account that Microsoft Internet Information Server (IIS) is using (which is usually IUSR) does not have the correct Windows NT permissions for a file-based database or for the folder that contains the file.
  • The file and the data source name are marked as Exclusive.
  • Another process or user has the Access database open.
  • The error may be caused by a delegation issue. Check the authentication method (Basic versus NTLM), if any. If the connection string uses the Universal Naming Convention (UNC), try to use Basic authentication or an absolute path such as C:\Mydata\Data.mdb. This problem can occur even if the UNC points to a resource that is local to the IIS computer.
  • This error may also occur when you access a local Microsoft Access database that is linked to a table where the table is in an Access database on a network server.
Resolution
  • Check the permissions on the file and the folder. Make sure that you have the ability to create and/or destroy any temporary files. Temporary files are usually created in the same folder as the database, but the file may also be created in other folders such as the WINNT folder. For additional information about how to identify which folder does not have the correct permissions and how to configure temporary files, click the following article number to view the article in the Microsoft Knowledge Base: 253604 (http://support.microsoft.com/kb/253604/ ) Microsoft Access 97 database connectivity fails in Active Server Pages If you use a network path to the database (UNC or mapped drive), check the permissions on the share, the file, and the folder.
  • Verify that the file and the data source name (DSN) are not marked as Exclusive.
  • The "other user" may be Microsoft Visual InterDev. Close any Visual InterDev projects that contain a data connection to the database.
  • Simplify. Use a System DSN that uses a local drive letter. If necessary, move the database to the local drive to test.
  • Follow the instructions in the following article to work around this problem: 189408 (http://support.microsoft.com/kb/189408/ ) FIX: ASP fails to access network files under IIS 4.0 and IIS 5.0
Oct 16, 2009 | Microsoft Access 2003 for PC
Drawing in Visual Basic 6.0
Hi - You cannot scan directly into VB6 unless you use a third-party control (OCX). You would need to get the data into a database table and use ADO, or, hard-code the data directly into your source code. You can actually grab it from Excel too but that involves automation programming - not hard to do - just more to learn. Have fun!
May 12, 2009 | Microsoft Visual Basic Enterprise Edition...
Free visual basic source code salary database sample
you solution is her
Building Websites with VB.NET and DotNetNuke 4/by Daniel N. Egan (Author), Steve Valenzuela (Author), Michael Washington (Author)
Description
DotNetNuke is an open-source Content Management System and web application framework. DotNetNuke has taken the Microsoft world by storm and now at version 4, its community has grown to over 200,000 users. This book covers virtually everything you need to know to get your DotNetNuke website up and running. Concisely written and with clear explanations, this book is covers installation, administration, deployment, site creation and all of the basic built in DotNetNuke modules. For developers, chapters on the core architecture, skinning and custom modules, including coverage of the DAL+, give you the skills to customize and extend your site. The book starts off by giving you a deep understanding of working with basic DotNetNuke sites, guiding you through the features and giving you the confidence to create and manage your site. After that, you will journey to the heart of DotNetNuke, and learn about its core architecture. Always concise, relevant and practical, you will find out what makes DotNetNuke tick, and from there, you will be ready to customize DotNetNuke. Developers will enjoy the detailed walkthrough of creating a new custom modules. Special emphasis is given to the DAL+, an extended feature set of the DotNetNuke Data Access Layer (DAL). You will see how to create custom modules with the DAL+, and invigorate your module development. Web designers will enjoy the material on skinning, helping them to create a new look for their site. You will learn about creating new skins, and packaging them up for easy deployment. You will master all of this as you leap into the development of a DotNetNuke 4 site. This book will give you the skills to create and manage DotNetNuke websites as quickly as possible. You will:
* Install and configure DotNetNuke
* Master the standard modules
* Understand the core architecture of DotNetNuke
* Explore the inner workings of DotNetNuke modules
* Extend DotNetNuke using the DAL and DAL+ to create powerful custom modules
* Create your own skin using a HTML Editor
* Find out about where and how to host and deploy your site
You can use this book to help you set up and administer a DotNetNuke portal, even if you have a limited knowledge of ASP.NET. You will learn how to setup and administer an example site, stepping through all the tasks to ease your learning. If you are a developer, this book will help you extend the DotNetNuke portal by first helping you understand how the core framework works and then show you how to create custom modules and skins. A rudimentary knowledge of VB.NET programming is assumed, but the emphasis is not on becoming a better VB.NET programmer but on taming DotNetNuke. This book has been written for both the beginner wanting to set up a website and also ASP.NET developers with a grasp of VB.NET who want a deeper understanding of how to work with DotNetNuke. To work with the DotNetNuke code, you will need access to Visual Web Developer Express or Visual Studio .NET 2005. No prior knowledge of DotNetNuke is assumed.
download link:
http://w14.easy-share.com/1701584071.html
or:
http://dep
May 03, 2009 | Microsoft Visual Basic Enterprise Edition...
I have a visual basic program in which i have to display the record from access table by using connection of adodc.and then select record from datagrid will display in another form. plz reply as soon as...
hi,  you may visit this site www.kidwaresoftware.com/ and download all free visual basic source codes with tutorials..  One of the source code will solve your problem.    However their paid Visual basic source codes will most powerful.    As I am total deaf and no source to communicate others... I want to share the  payment source codes with tutorials from  www.kidwaresoftware.com/.  Are you ready... If you download the  source codes with tutorials (only Fee for it) I will share with you.    esakkisivaganesh@yahoo.co.in
Apr 08, 2009 | Microsoft Visual Basic Enterprise Edition...
I want searching code for visual basic 2008....which can search the required information from a database...in my case database is FIR...if i input the FIR number..i want to show the correspoding...
Not much code needed in Visual Basic for this one. Visual Basic would only show the data actually. The search on the database is actually just one query statement. query = Select * from databasename.tablename where FIRnumber=?. where ? is the input in a textbox.
Apr 02, 2009 | Computers & Internet
My vb proj.works in my pc bu not in the org. for it has been made
You should use Package & Deployment wizard (its there in visual studio 6 only under menu)
Create a package, include all dependencies, include database file (i guess you are using msaccess)
Once the package is created, go to Deployment wizard, to include the package created, you'll then get one Setup (as usually softwares are packaged)
If you go like this, you dont have to worry about the dependencies in your project or any runtime lib that might required.
It will work anywhere where you install your software like u usually install others.
Hope this helps.
Thanks.
Mar 18, 2009 | Microsoft Visual Basic 6.0 for PC
I can't add data in the database using vb
The database can be any like oracle.
Two type of connection u can make.
One of such connection is ADODB
The code is like
Dim ors As ADODB.Recordset
Dim oconn As Connection
Dim Qry as String
dim Qry1 as string
Set ors = New ADODB.Recordset
Set oconn = New ADODB.Connection
Chk_selectall.Visible = False
oconn.Open "Provider=MSDAORA.1;" & "user id = " & Username & _
";password = " & Password & ";data source = " & Conn_string _
& ";Persist Security Info=True"
Qry = "insert into table1 values (100,'we')"
oconn.execute "Qry"
If u select any data then u ve to use
Qry1 = "select * from table1"
ors.open "Qry1",oconn
do until ors.EOF
msgbox ors(0) & "," & ors(1)
ors.movenext;
loop
Mar 17, 2009 | Microsoft Visual Basic 6.0 for PC
What is the compatible database for visual basic 6.0?
Microsoft Access uses the Jet Engine. In VB 6, you can create a data connection using ODBC or OLE DB. Here is an example of OLE DB:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\YourAccessDB.mdb;User Id=;Password=;" Good luck
Mar 09, 2009 | Microsoft Press MS Access 2000 and Visual...
How do copy a table from an access database in one folder to another access database in another folder through visual basic code
Simple method Open both tables (or create second) and copy each record from source to target through 'do while not eof' or 'for each' syntax.
Second solution create link in target DB for first table, and use SELECT INTO statment in SQL.
Mar 02, 2009 | Microsoft Visual Basic 6.0 for PC
Microsoft Visual Basic 6.0 for PC Logo
69 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
