Question about Garden
Homelite ut-10942-a chain stops under load
My homelite ut*10942-a 45cc 20" (low hours on saw) it revs up just fine and the chain spins but as soon as i try to cut the chain slows to a stop and the engine dosent slow.
i took it apart and the clutch looks to be in good condation.
the shaft that the clutch is on spins freely in both directions
i can spin the engine and hold the clutch staitonary
any suggestions
thanks stephen
    Brigadier General:
  • 4,088 Answers
Could be the internals of the clutch have been heavily oiled--wash out with carburetor cleaner from an auto parts store. The internals of the clutch expand to the internal rim of the clutch housing when things rev up. Oil blocks the necessary friction needed between those parts. Make sure the chain sprocket is attached firmly to the clutch housing.
Posted on Jul 04, 2009
I need a manual for Homelite Texron #105064
I found this download link for the Homelite chainsaw ut10506-4 parts manual, if it is helpful.
http://megaslides.com/doc/9405595/homelite-chain-saw-parts-manual-for-xl-chain-saw-ut-10506...
No operators manual found.
May 02, 2017 | Homelite Garden
I have a Homelite UT 10518 46cc 18" saw. The replacement chain for that model does not fit the bar (not long enough) any idea what is up with that - also the 10518 does not seem to be listed on the...
you need a 72 link chain .375 pitch .050 guage at home depot the blue powercare B72 should be the one you need at lowes it oregon H72 there are other brands as well but you need to make sure of the links guage and pitch when buying a chain
Jan 15, 2011 | Homelite FactoryReconditioned ZR10522...
My homelite chainsaw model# ut10520 has aoil leak from the flexible line at the base of the oil tank.
I input your model number and found 3 possible matches, "42cc/46cc Chain Saw UT-10520; SUPER 2 Chain Saw UT-10520 or SUPER 2 Chain Saw UT-10520-A".
I opened the first "Ref # 3" on "Figure A" I suspect is what you say is leaking. It is very inexpensive and available. I would order one and inspect it once recieved to determine an installation method. It does not appear overly difficult without the part in hand. Good Luck.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 07, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Need service manual for Homelite 16'' electric chain saw model UT 41320. Motor runs but chain stopped in middle of second cut.
chain is too tight on the bar or is lacking lubrication oil. loosen up the bar nuts and back off the chain tensioning screw a touch. make sure the bar oil reservoir is full and the chain is receiving oil when its running.
Oct 20, 2009 | Homelite Garden
Chain dies under light load, engine running ok
It sounds as though you have abraded away the clutch face. I’d try a local saw seller/mechanic, they may be able to adhere a new face to your existing parts.
I went here:
Homelite/Ryobi.com
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Chose “38cc 16" Chain Saw UT-10927” and on the “Clutch – Chain Brake – Drive Case Cover” detail found; item 20, clutch, pn984894001, $15.47; item 21, sprocket and drum assembly, pn984640001, $18.46
Yours is an inboard clutch but it must be removed, the outboard clutch video will help.
R² Drive Link Inboard Clutch
http://www.youtube.com/watch?v=YUbSIHMSSP8&feature=PlayList&p=4A4A1DF66590854E&index=0&playnext=1
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
    Lou
Oct 09, 2009 | Homelite Garden
Need replacement Chain oil pump
Go to the Homelite web site, which will get you to HCPI Electronics Parts catalog. You will need the model number. The parts are illustrated as a break-away drawing for various portions of the saw. Hope this helps.
Aug 29, 2009 | Garden
Homelite ut No. 10748 textron New sitting long
Is there bar oil in the tank? Oil pump and/or pickup tube in oil tank are usual suspects.
Jun 29, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
289 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
