2006 Fiat Grande Punto Logo
K
Kedisha Coakley Posted on Jul 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is my Fiat bleeping from the inside?
When i start the car a bleeping sounds from the driver side dahboard, it stops once i start driving. When the key is taken out of the egnition the bleeping sound again for about 20 seconds. What is my car telling Me?
Rick
Level 2:
Habit-Forming:
New Friend:
  • Expert 101 Answers
  • Posted on Jul 28, 2014
Rick
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
101
Questions
0
Helped
41742
Points
251
Its an audible warning, is your door closing properly? seatbelt connecting in the latch correctly? handbrake correctly released?, also check the boot and bonnet is secure and latched. Check the dashboard do you have any warning symbols, low oil fuel etc or a service indicator or warning light usually an engine shape or a service due message will be on your dash.If you are not sure go to a garage.
4 Related Answers
Anonymous
  • Posted on Jul 12, 2009
SOURCE: every time i drive my fiat car for more than 4 min
check that your injectors are not leaking around there housing, as this was the problem with my doblo. (first injector) to the right handside as you look at the engine.
Anonymous
  • 70 Answers
  • Posted on Jul 27, 2009
SOURCE: fiat scudo starts and runs for 8 secs then cuts out
8 seconds and stall,..
Sounds like you're starting fine and there's no apparent problem with the engines electrical impulses in regards to wires, plugs, coil etc,..
Which it sounds like you're running off residual fuel but continuous fuel supply is being disrupted.
I'm all but certain if you pull a SP it'll have unburned fuel on it. Check your fuel pump, filter, pressure regulator and injectors
From those symptoms the pump could be faulty, filter clogged and only feeding seepage, the regulator could be flooding it out ot the injectors aren't opening { clogged }
What do you get when you try to press the accelerator when it's running or have you not tried that?
Anonymous
  • 1857 Answers
  • Posted on Feb 22, 2010
SOURCE: Central locking problems
Aot of cars have problems with the actuators binding up. The sympton is you see or hear the switch trying to but wont.
The only fix is to replace the units.
Denny Giesel
  • 818 Answers
  • Posted on Nov 11, 2013
SOURCE: fiat ulysee JTD 2002 turns over but wont start
your fuel pump may have broken loose inside the fuel tank-I have seen that happen in rear end hits -it may be intermitatly be working but needs to be replaced-cheers Denny
Testimonial: "Thanks Danny, is there any "easy" way of finding out?"
I have a 2012 Fiat 500 that when you first start it it is quiet and then when when you drive it and it worms up it sounds like a diesel engine..
When a petrol engine starts making heavy mechanical noise it is potentially bad news and it is time to ensure there is adequate engine oil inside and then drive it slowly and gently to the nearest expert to have the noise identified.
How to remove a broken window mechanism in a Fiat Strata Bakkie
To get to a window mechanism, the inside panel has to be removed. Locate all screws that hold the panel handle and any other part of the panel to the door frame. The sides and bottom of the panel are held in place by panel retainers , which pop out of the door frame. Place a panel tool or flat screw driver along the sides and bottom to pop out the retainers. Once the sides and bottom are free t, the top of the panel should lift up out the track on top. Be careful of any wiring before you remove the panel.
1helpful
Fiat strada
remove the door trim and adjust the window guides inside the door
2answers
Why does my seat leon fr flash 20mph and bleep when driving over 20mph
U HAVE ACTIVATED SPEED WARNING!!USE MANUAL TO DEACTIVATE!!
How to repace drivers side wing mirror on fiat stilo
easy pull the plastic trim off the inside back of the mirror ,inside the car?' then three screws hold it on ,simple a 5 min job at most
2answers
3helpful
Airbag and ESP lights on dahboard
my power steering light comes on and off, and the car will not switch on once turned off, its draining the battery??
Top Fiat Experts
ZJ Limited
ZJ Limited
Any Car Diagnostic...
Sean Wright
Sean Wright
Are you a Fiat Expert? Answer questions, earn points and help others
