Question about Dryers
I have a whirlpool dryer will not heat
I have a whirlpool dryer when turned on the drum works the glow plug goes on but no gas lights than glow plug goes out this happens about 3 times in the cycle
  • 999 Answers
Either the glow bar is weak or the valve coil is failing. Measuring the amp on the coil is the only way to be sure. If the burner lights once in a while it is most likely the coil,
eric
Posted on Jun 30, 2009
Dryer turns on and lights , heats approx. 1 min. goes out when up to temp, stays off approx 1min. lights again, may do this for 5 times then just doesn't relight. Stays cold, keeps spinning drum. ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | GE DCVH515GF Gas Dryer
We have a 10 year old Whirlpool Dryer Model #LGB6200KQ0 drum is turning but no heat. Could you please advise?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LGV4634JQ Gas Dryer
Gas whirlpool dryer model LGR6611LQ0 will not heat up . Ignitor turns on but will not light
heatman101
Dec 19, 2010 | Whirlpool LGR5636L Gas Dryer
Drum is turning but no heat. Circuit breakers are on. No code comes on and it doesn't progress from "sensing" status. What is the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 26, 2010 | Whirlpool GEW9200L Electric Dryer
Why won't my dryer heat up and dry clothes. The light comes on and the drum turns, but no heat comes from the dryer. It is a gas dryer and there is gas available. The settings are in the same cycles I've...
heatman101
Aug 01, 2010 | Whirlpool LGR7646E Dryer
The dryers does not light
I will be happy to assit you with this issue
I have a web side that will help you.
http://www.youtube.com/watch?v=f1rebeCMVsk&feature=fvw
was this helpful?
your rating is very important so I can help others.
thank you
Oct 18, 2009 | Kenmore Dryers
Gas dryer not heating. Drum does turn. Tim,er
The dryer has a bad thermal fuse . A small slim white piece with 2 wires attached . IF you do not see the glow from the ignitor .
Jul 15, 2009 | Whirlpool Dryers
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer will turn but won't heat.
Check the gas valve in the back of the unit and also check the Glow ignitor to make sure that you are igniting the gas to heat the drum. Sounds more like it is the Glow ignitor that is bad
Feb 09, 2009 | Whirlpool LEB6200 Electric Dryer
No heat
Check the glow plug.
Take off the bottom front panel, push the start button and look for a red glow. This glow plug is about the size of your little finger and is hard to see when it's off but you will see a red glow if it's working. No glow, replace the glow plug.
If it glows for a few seconds then goes out then the solenoids on the gas valve should be checked with an OHM meter.
Dec 16, 2008 | Dryers
Dryers Logo
42 people viewed this question
Top Dryers Experts
