The machine fills with water but does not agitate or spin. The timer is working.
  • rdavandiver Jun 30, 2009
    It is a Kenmore model 82873820 top loader
  • Gilbert Martinez May 11, 2010
    What brand is it?. Some have a coupling on the motor shaft and it could be cracked or broken.
    Sergeant:
    Champion:
  • 235 Answers
The coupling on the motor shaft is broken or cracked. Part runs for about 10 bucks.
Posted on Jun 30, 2009
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Won't finish the final spin
    It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Post further comments for more information ....
    Good Luck!!
    Thanks
    Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    It keeps getting stuck on rinse cycle a
    Check it out....
    Good Luck!!
    thanks
    Jul 19, 2009 | Fisher and Paykel Washing Machines
    The washing machinge is not completing the complete cycle
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    My washing machine is not changing cycles. It fills, drains and refills. It sat unused for 1 year. 12 months ago it was working fine.
    Hi there. I can help you.
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. If this is the case, turn off the water and remove the hoses. Check both hoses to be sure the filter screens are not clogged with crud and that the hoses aren't kinked.
    Jun 18, 2009 | GE WSXH208A Front Load Washer
    Stuck in spin
    Hi!
    If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
    It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
    Do rate the solution as FixYa and revert for further clarification.
    Thanks
    Rylee
    Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    As washer was on final spin cycle it sounded like a belt came....
    Apr 01, 2009 | Kenmore Washing Machines
    Washer won't advance from cycle to cycle
    * It's the timer, if your washing machine fills with water and begins agitating, but the timer never
    the timer.
    * It may be a cold-water supply problem, if the washing machine fills with water, agitates,
    Nov 16, 2008 | Danby DDW1805W Designer Series...
    Machine fills with water & then clicks but goes no further. It will drain but no other function seems to work
    That is probably a problem with the timer.
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • Oct 11, 2008 | Bosch Washing Machines
    Whirlpool AWO3761 stuck mid-cycle
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Washing Machines Logo
    32 people viewed this question
    Top Washing Machines Experts
