Question about Garden
The PTO seems to stop running for no apparent reason. You turn it off and then back on. It seems like there may be an issue with the electric clutch that drives the blades. Any thoughts on what to do? Should I replace the electric clutch? Where do I get one at a reasonable price?
Probably not the clutch. sounds more like a bad ground or a bad switch or both.
Posted on Jun 30, 2009
Craftsman zero turn 26 hp kohler engine new pto electric clutch does not work
Sad to say it may have never been a bad pto clutch but probably safety switch problem. The running tractor wants you in the seat, brake off, levers over your lap and not backing up for the PTO to stay engaged . There is two push button switches on each lever that lay over your lap ,one on the parking brake,one under the seat. All of these switch wires meet at the PTO switch and all have to agree they are in the position they need to be in to allow electricity to come down the wire to the PTO Clutch.
Dec 22, 2016 | Craftsman Garden
Troy-Bilt Colt XP. Start engine and begin mowing and everything is fine. After a few swipes on the yard, 2-3 minutes, PTO shuts off. turn off and back on works shortly. PTO clutch getting hot???
electric pto clutches get HOT (not warm) for only a few reasons
(1) worn out friction disks inside
(2) foreign object(s) not allowing clutch to fully engage a good blast of high pressure air knocks out most stuff , if let go to long this leads to 1st reason
Jun 29, 2015 | Garden
Blows a fuse every time I engage the cutting deck
it is not supposed to start unless some one is in the seat
now for your problem, if engaging the cutter deck blows a fuse then check the wiring for a wire that is cut or shorting out on a lever that moves when the cutter is engaged
Apr 18, 2015 | Garden
Electric clutch wont engage when when switched on even though I can hear a clicking sound at the clutch.
PTO Clutch will not stay engaged.
There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
It does not give the air gap. It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 11, 2015 | Swisher 60" 26 Hp Zero Turn Radius Riding...
What could the possible reasons why the pto will not disengage on my MTD 42" Zero Turn Mower.
Basically your PTO is an electro magnetic clutch....when power is applied (12 volts) from the battery, the magnet is energized and the two plates come together and you have then energized your PTO clutch and it should drive the V-belt....so If you disconnect the power to the magnet the magnet becomes denergized and the two plates move away from one another ,thus the v-belt stops turning .
It could be the switch,or more than likely it is a "relay" that has gone bad ,ie, the contacts on the relay have become pitted with use and stick when they get hot from use....thus when you disengage the PTO switch the relay stays in contact thus delivering power to your PTO clutch .....if you have a wiring diagram of your unit you should be able to find the "safety or PTO relay" again this is just my theory!
If you can use a meter,you could check for voltage on the PTO wire when you disengage the PTO switch,if power is still present then we know it's an electrical issue with the switch or relay ,OR some how power is back feeding down this wire that keeps the clutch energized????? Maybe two wires making contact ????
Unfortunately a good small engine mechanic may be the way to go on this repair ......most people have a clutch that won't engage !
I hope this sheds some light on your issue ,Jim
Feb 11, 2015 | Mtd Gold 42" Zero-Turn Mower -
I was mowing and the blades stopped turning. I disengaged and re-engaged the blades a few times and they started back. Then a few minutes later the blades stopped again then the motor stopped and will...
I have no idea what type or model of mower you have but if I was to guess I would say it has an electric pto clutch on it, if so remove your pto belt and clutch. I would bet it is burned out and locked up preventing your motor from turning over. Once the clutch is removed I will bet it will start and run fine. This is not a cheap fix but relatively easy one. Hope this helps.
Aug 21, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
On a Husqvarna 2005 ELS 2448 riding mower, PTO switch burns up, and wont blow the fuse first? Why?
I used to see this on the Kawaski engine machines with an electric clutch, they put a diode between the two clutch wires so as so as to stop any electrical feed back throught the clutch, when the machine is running without the clutch engaged it can turn into a generator.
Oct 17, 2012 | Garden
My electric pto is not working properly. It shuts off and does not turn back on when theswitch is pulled
I've had the same problem. Intermittent shut-off of the pto. Found out that the pto (electric clutch) draws heavily on the battery current to stay engaged.Clutch is actually an electro-magnet. I bought a new battery (300 cca) the bigger the better and clutch now works fine. Old battery was still strong enough to start engine but not strong enough to engage pto. Old battery was 4 yrs old. A good clutch will click if jumper wires from the battery to clutch wiring harness are connected (with out motor running.)
Jun 02, 2010 | Oregon Scientific Electric PTO Clutch for...
I think i may need to replace the pto clutch on my stx38...is it difficult to do? Also, how can i best determine whether it is the pto clutch or perhaps the switch that activates the clutch. currently,...
Depending on the age of the mower, it sounds like a wire has wiggled lose, or the switch itself has gone bad. I would check the wiring to the switch and to the pto clutch and ensure that all wires are secure, free of corrosion. If this still doesn't fix the issue, install new switch. This appears to be entirely and electrical issue, and is a cheaper troubleshooting method before tearing down the pto engagement system.
Let me know!
Chip
May 31, 2010 | Garden
Craftsman 26hp Garden Tractor PTO not working
If you changed the belt make sure it did not interfere with the wire that runs from the pto clutch, sometimes that belt can rub on the wire and wear through it,also if you had the clutch off make sure you aligned the steel retainer bolt that sets in the alignment hole on the pto clutch,this keeps the clutch from spring when disengaged if you don't get that pin through the hole in clutch it can push on the clutch and bind it.Also it may be possible to plug that pto switch in backwards.Also if you jumped the fuse out it may now have burnt the switch or wiring somewhere.
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
