Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Red lamp light on no pic
I have sound no pic and red lamp light on
  • 80 Answers
The power supply has gone bad inside your tv. so wen you take to the manufacture, he will replace the power unit, your problem will surely get solved, thank you,, plz rate me,,,
Posted on Jun 30, 2009
Mitsubishi WD-65733 Red light on Replaced lamp twice
I'd just replace my lamp just three days ago and the problem still
exsist
Nov 10, 2013 | Mitsubishi WD-65733 65" HDTV
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
No pic/sound lite blinks red and sometimes lamp
Need lamp replaced first.Find out it work or more problems to fix.
Jan 07, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Replaced lamp ,have sound but no pic,shuts down
Thats the code for whats known as lamp abnormality which is actually caused by failed capacitors on the power board. Heres a link to the repair kit that will usually fix that issue. The kit contains the replacement capacitors and also has step by step detailed instructions with photos so you can easialy do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jun 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp light stays on. No pic or sound. Can I get a new lamp and change it myself?
No. This model does not use a lamp. Could be a hundred different things cause this symptom.
Mar 30, 2009 | Hitachi 51F59 51" HDTV Projection...
Red and green flashing and a pop.
No it your lamp has failed this time. Replace it and you should be enjoying ur television again.
The pop sound was the lamp shattering in its housing, does'nt get into the television tho. You can save money by just buying the bulb and installing it into your original lamp housing.
Please leave comment thank you./.
Dec 22, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
No pic...humming noice on 62'' toshiba dlp
was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
Nov 19, 2008 | Toshiba 62HM95 62" HDTV
Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Dec 04, 2007 | Sony KDF-E55A20 55 in. LCD Television
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
