Question about Dell Dimension 8300 PC Desktop
Upgraded Hard drive fron 40 gig to 250 gig, used 250 before as main hard drie, been using as external drive.Formatted it and put in computer, Windows will install all files but not complete set up. Wiped disc with Disc Wipe Pro 4, then reformatted, same results. The copy of Windows is good, I installed it on another pc 2 days ago, I think it's the HD. Any help would be appreciated.
  • donaldhantzs Jun 30, 2009
    This is true, but only 250 gig in pc when installing windows. Wiped drive with disk wipe pro 4, all sectors are good, then formatted to NFTS, installed drive, windows vista ultimate will load all files, but not finish the set up. Tried that copy of windows on 40g and worked perfect. Should I wipe the drive again and leave as a basic drive, or does it have to be NFTS to install windows. Thanks for helping.
  • 127 Answers
Diconnect 40 g while install windows on the 250g seems like it is picking up windows off the other one while installing
Posted on Jun 30, 2009
  • reese911 Jun 30, 2009
    is the copy of windowa vista a upgrade disk you downloaded from a torrent by benjemin or a store copy?
MYSEAGATE 500GB SATA HARD DISK IS NOT RECONGNIZED BY COMPUTER
If you are using it as a external drive you will find in my computer. If your using it as a new main drive it may have to be formatted .
Jun 29, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
SimpleTech 250 gig external drive not recognized on MacBook
It could be formatted in a different manner. See if it is detected by your mac. Go to Applications/Utilities/Disk Utility and see if your hard drive is shown there. If it is, then the formatting of your hard drive is not compatible and you will need to reformat to be able to use it on a mac.
Nov 02, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
How do you set up an external hard drive?
Turn your computer on and plug the external hard drive into the computer.
Open "Computer Management" by clicking "Start," "Control Panel," "System and Security," "Administrative Tools" and "Computer Management."
Click "Disk Management" in the left pane under "Storage."
Locate your external drive from the list of hard drives connected or installed on your computer.
Right-click the drive and select "Format."
Select a file format from the drop-down menu. Choose "NTFS" if you will be using the external hard drive with a computer that uses Windows 7, Windows Vista or Windows XP.
If you will be using the hard drive with an older version of Windows, select "FAT32."
This is a much less common format.
Click "OK" twice and your external drive is formatted. Once the drive is formatted, it is properly set up to be used with your computer.
hope this helps
Sep 10, 2012 | Computers & Internet
I have toshiba 250 gb HDDR250E03X i am unable to write a data of 4 gb or more(single file of 4 gb or more)..?
Hi this is a file system issue. It is probably formatted in fat32, which does not support files above 4 gigs.
To solve this problem you'll need to reformat it (my computer => right click on the drive => format), using ntfs file system (under file system select ntfs).
Note:
THIS WILL ERASE EVERYTHING FROM YOUR DRIVE!
So back up everything before proceeding.
After it is done you will be able to copy files of any size onto it.
Alternative solution: download winrar and split your files into chunks smaller than 4 gigs.
Jun 30, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Its a 250 gig hard drive and its saying that the memory on the hard drive is a 14.9 gig hard drive. it won't allow for it to put windows 7 back on it. It says there are no drivers on the hard drive on...
This hard drive needs to be repartitioned and formatted first then you should see actual amount. You can do this when selecting the drive in windows 7 installation
Make sure the drive is listed in the BIOS matching your serial, model number, etc incase you purchased this from ebay or second hand.
Mar 11, 2011 | Samsung HM250HI 250 GB SATA Hard Drive
Running Windows 7 Home premium. External drive Verbatim USB 250 Silver is recognized, but, needs to be reformatted. I've tried to format (NTSF) using tool in Disk Management. Format runs forever and...
Hello and thank you for using Fixya's services.
This problem happens quite a bit with Windows Vista. It seems that Windows Vista puts a hidden file in the backup; which locks the device.
Open the external device (Windows 7 is fine). Click on "view hidden folders and files." Delete any hidden files you may have in the external.
Go back to "my computer" and right click on the external hard drive letter. Choose properties and security tab. Make your user-name as a main user (administrator) and disable the read only.
Reboot the computer and see if this works.
Please let me know if you have any questions.
Nov 04, 2009 | Office Equipment & Supplies
Mac not allwoing write permission to an external hard drive
As long as the Esternal is formatted correctly it should work fine, it might be that you computer wont read the hard-drive, not the files.
Jun 16, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Formatted (on PC) 1TB WD hard drive cannot be altered on Macbook
What OS are you running? What is it formatted as FAT32 or NTFS and how big are the partitions. Various operating systems, hardware and formatting schemes have different limitations. If you want to use the drive in Leopard formatted with NTFS which is the only way to create partitions larger than 20 or 30 GB you may need to install an NTFS file system driver like FUSE.
The other option is to format it as HFS and install Macdrive 7 in Windows to use Mac formatted drives in Windows.
Hope this helps.
Dec 27, 2008 | Western Digital 250GB MyBook External USB...
Backup hard drive to an external hard drive
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Dec 13, 2007 | IO Magic Corporation GigaBank (I250HD35)...
Dell Dimension 8300 PC Desktop Logo
225 people viewed this question
Alun Cox
