Question about Sony DVP-NS575P DVD Player
Can't switch my dvp 575 from progressive to
Can't switch my dvp 575p from progressive to interlaced
bbtoast
  • 319 Answers
SOURCE: Not able to turn off Progressive scan feature-sony dvp nc85h
Are you pressing the Progressive Scan button on the front of the Player? You need to look at the BACK of the Player. There is a manual switch just below the words "LINE OUT". This needs to be moved to the left where it says "Normal"
Try this please!
Brian
Posted on Jan 08, 2008
SOURCE: denon dvd player is in progressive scan-need it in interlace
used single composite video plug to get back to setup.all is good again
Posted on Dec 26, 2008
SOURCE: Cyberhome DVD-1600 In the settings menu I went into the A/V setup. The scanmode was switched to Progressive; however, nothing showed and after the 10 seconds it did not revert to interlace. Now I'm ge
Cyberhome DVD-1600
To set the factory default settings just do the following:
  1. Get the DVD-1600 manual
  2. Open to the page which shows you how to set the player to factory default settings
  3. Switch on the TV and click to the channel that you will watch your DVDs
  4. Switch on the DVD player and make sure there is no disc in it - this ensures the DVD is not already in a menu or any other thing
  5. Follow the instructions in the manual to the 'T' although you will be unable to see anything
  6. If you follow the instructions correctly you should get back to 'interlaced mode'. By this time you will be able to see the DVD output on the screen.
Posted on Apr 13, 2009
  • 64 Answers
SOURCE: progressive/interlaced image problem
In the Initial Settings Menu go to Component Out, ther you can switch it.
Posted on May 16, 2009
If it works like my sony RDR-GX315 just press the pause button on the player itself and hold for 5 seconds.
Posted on May 17, 2009
NO VIDEO BUT HAVE SOUND
Good day! Try to check the rca jack video input.Replace it with new one if defective. Also check the progressive scan features if activated. If it is activated check your TV if supported by progressive scan features, because some TV is not supported by progressive scan.You can deactivate it by turning off or activate the interlace mode.Press the open/close to open disk tray. And press the numeric keypad 1 for few seconds. Hope its help.
Sep 07, 2011 | Philips DVP-3005 DVD Player
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
I am stuck in the Progressive Scan Mode on my DVD player & cant get it out of the blue screen. I have tried reseting it & even unplugging the player.
If your TV does not support progressive scan, you won't be able to get out of the blue screen. The only way to solve this issue is to connect the unit to a multistandard TV which has this capability, then in the player's on screen menu, look for anything that would allow you to select either progressive or interlace as its video output (or has progressive on and off feature) - and switch progressive 'off'. This should revert the output back to interlace. Then unplug the combo, reconnect it to your original set, and it should work fine after that.
Not impossible to correct, but a real pain if progressive is selected in a DVD player's output and the TV does not have that feature. Some DVD players have progressive output as a default option in their setup. Reverting it to interlace or turning it off so it matches the TV it is connected to should solve this problem.
Feb 16, 2011 | Goldstar GBV241 DVD Player/VCR
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
Progressive/interlaced image problem
May 16, 2009 | Pioneer DV-300-K Player
If i use progressive it only show me a blank screen on tv. but if i switched it to interlaced i can access ny psp on tv nut i cannot play the UMD. What should i do?
Your tv does not support progressive . With interlaced you cannot play games on tv. Most or all hdtvs have progressive scan, at the same time most standard def tvs do not.
Mar 15, 2009 | Sony PlayStation Portable (PSP) Console
Split Screen
Go into SETUP
GENERAL SETUP PAGE
Go to VIDEO OUTPUT (can't see through error message, but it is the second one down - If you are on the right one, you will see S-Video, YUV Interlace and YUV Progress. as choices)
Change setting from YUV Progress to YUV Interlace
Mine was set on YUV Progress. and when I changed it, the problem disappeared.
Mar 06, 2008 | RCA DRC200N
Jan 08, 2008 | Sony DVP-NC85H Multi-disc DVD Player
No picture
It is probably in "progressive scan" mode, which is only viewable on Component (RGB) inputs. Refer to manual to toggle back to "interlace" mode. Either that or you have the TV on the wrong input.
Sep 10, 2007 | Sony DVP-NS57P
Closed caption on dvds
Your TV will need to have (CC) capability. To view Closed Captioning (CC) information from a DVD using the CC function of the television, turn off the Progressive Scan function of the DVD player. If the DVD player doesn't have progressive scan then follow the instructions from your TV manual to setup closed captioning.
Jul 14, 2007 | Sony DVP-NS575P DVD Player
Sony DVP-NS575P DVD Player Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
