Back to:
Tags:
JVC GR-D370 Mini DV Digital Camcorder
JVC GR-D53AA MINI DIGITAL CAMCORDER (by 12 users)
posted by WEBSTER2 on Nov 08, 2007
WHEN YOU TURN IT ON IT SAYS THAT THE LENS CAP IS ON AND WON'T SHOW ANY PICTURES
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
11 Other Users Have The Same Problem
Comment by Guest, posted on Aug 14, 2008
Same problem it say's the Lens cap is on and theres no picture
Comment by buba310, posted on Jun 26, 2008
put on power tells me lids on and its not
Comment by Rando, posted on May 28, 2008
Same here, just started 26May2008. Is there a service manual available?
I used to be a camera repair technician for Kodak here in Oz but I cannot find a service manual for this one: JVC GR-D53AA
Any help would be appreciated.
Comment by Guest, posted on Apr 30, 2008
Turn cam on and it says that the lens caps is on, but its not.
Comment by zaco, posted on Mar 17, 2008
when i put it on auto it says lens cap and there's lines going down the screen, i tried cam reset but it was still black. i think the problem is in the ccd
Best Solution
posted on Dec 28, 2007
FixYa! (100)
kstahly
Rank:Guru Guru
Rating: 93%, 34 votes
Apparently this same problem exists on many different models. I have a JVC grd72u. I called JVC @ 800-252-5722. I selected the "Corrective Action Program" prompt from the automated attendent. I spoke to a customer service rep. They are aware of the problem and are fixing it for free, but only until 12/31/07. I suggest you call ASAP and get your name in the computer. If the problem is something besides the CCD sensor, they will call you with the estimate to repair.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on JVC GR-D53AA MINI DIGITAL CAMCORDER:
I don't want to Accept this solution
Solution #2
posted on Dec 21, 2007
Not Rated (0)
vidkid99
Rank:Master Master
Rating: 82%, 9 votes
Jvc has a chronic problem with the soldering of wires going to the CCD (the part that captures the image). If the camera is out of warranty, this a $100 repair by JVC. They just solder loose wires....
Thank You!
Can you Help with these Camcorders problems?
I have the Jvc Gr-D371U camcorder.I am trying to get my...
Can't record, yellow icon appears with error lense cap on
CAnt record on my camcoder GR-D750AH
I have the jvc gr-d371u mini dv camcorder.I have tried...
When it's in the play mode the screen is blue.....trying...
11 Other Users Have The Same Problem - Continued
Comment by Largs, posted on Mar 01, 2008
Same again here. Black screen with "lens cap on" indicated. For a while it did intermittently work but even then it would not adjust its exposure. eg too bright outdoors, screen goes white.
Comment by Guest, posted on Dec 22, 2007
SAME PROBLEM HERE!!!! ONLY BLANK BLACK SCREEN.....NO PIC :(
Comment by Guest, posted on Dec 17, 2007
i have a lens problem.all im getting on my screen is a blank dark screen
Comment by Guest, posted on Nov 25, 2007
When I open and turn it to play mode the message were: "Eject and re-insert Tape" then "Unit in safeguard Mode". I tried to re-insert the tape but the same messages were promt.
Comment by Guest, posted on Nov 17, 2007
same problem
Comment by kevps, posted on Nov 14, 2007
I have exactly same issue.
Loading problems.
Repair Service
Find Camcorder Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
