Question about Kenmore Dryers
Our Kenmore front-loading dryer (model 417.90042990) sometimes leaves small, linear scorch marks on relatively thin items likes sheets and shirts. It seems to me that the material slips into the seam between one of the plastic tumbler fins and the stainless drum and gets stuck there long enough to burn. Has anyone else encountered this problem or know a fix? Thanks.
  • 999 Answers
Actually check around the drum seals. Those marks can be rust stains as well. The seals may be worn out.
eric
Posted on Jun 30, 2009
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Brown marks on my light coloured clothes
I just noticed My Frigidaire doing the same thing. Using a lightly soapy damp cloth, I cleaned the interior, paying particular attention to the small gap between the drum and the housing. I also took apart the lint pre-filter and screen and cleaned them. There was a filmy build up of the same colored substance. I suspect that dryer sheets are leaving a waxy residue that over time is sufficient enough to rub off on lighter colored, primarily synthetic, fabrics.
Jul 11, 2009 | Kenmore Elite HE4 Electric Dryer
Burn marks on clothing
The front felt drum seal may be bad. It is attached to the front panel, around the door.
Check and or replace the rear drum support it has worn down the ball and cup support. It will soon begin making a grinding/squealing noise.
When it wears and drops down the gap is greater at the front around the felt seal. Laundry gets caught in the gap and scorches.
Apr 20, 2009 | Dryers
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes-snagging dryer
first check for any sharp edges, look inside around back and front of drum the felt seals could be bad.
Aug 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Brown streak on clothes
It could be from scorching due to getting too hot. This may be the start of a problem for you.
It is best to judge how long clothes need drying for before drying them. If they are left too long, sometimes the heat builds up.
Try a smaller load in there, and if you can reduce the temperature any then do.
Often it's just overloading is the issue.
Hope this is a solution for you, If so, Please rate as Fixya! Thanks.
Jun 18, 2008 | Kenmore Elite HE4 Electric Dryer
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryers Logo
191 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
