Question about Emerson LC320EM9 32 in. LCD HDTV
Tv is stuck on standby. won't turn on.
    Problem Solver:
  • 11 Answers
Most likely burned out, warentee should cover it if you have one.
Posted on Jun 30, 2009
3 Suggested Answers
  • 11 Answers
SOURCE: tv is stuck on standby. won't turn on.
Most likely it burned out.
dsacco86
  • 1077 Answers
Try leaving the TV unplugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
My 32" Emerson did the same thing. It turned out to be one bad Transformer Inverter on the Backlight Inverter Board. Something you may want to look at for your problem.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 02, 2009
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
Dec 27, 2015 | Televison & Video
My Baird jo47 won't turn on and the standby red is flashing with sound what is the problem
My baird JO47 tv is stuck on standby - Digital TV - Streaming ...
www.tomsguide.com/forum/55998-4-baird-jo47-stuck-standby
Dec 17, 2012 - 4 posts - ‎2 authors
My Baird JO47 tv is stuck on standby and won't come off. ... I have a panasonic 50" TV it will not turn on no green light or standby red light ... Forum; my tv standby light keeps flashing blue on and off and won't switch on Forum ...
Baird JO47 Stuck on Standby ' Electronics Forum (Circuits ...
Dec 15, 2015 | Televison & Video
TV won't turn on. Stays in Standby mode
Someone is going to have to go inside and check voltages and other things --no brand or model is indicated here so this is as much as I can suggest.
Dec 20, 2012 | Televison & Video
Tv won't turn on. Blinking in standby in red. Won't start
This is an indication of protection error and might require attention of a qualified service technician.
Aug 17, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony HCD LX20i audio shelf sysyem won't turn on. Standby light flashing. Disc stuck in it.
Check the speaker wires for shorts, if okay! suspect the audio output ic's, the protection circuit won't come out of standby because there is a short.
May 06, 2012 | Audio Players & Recorders
Tv won't turn on- its in standby mode. the young lad had the remote before it was turned on.... could he have pressed somethin on the remote which is now preventing it from coming on?
Powering up do you hear the relay click then you may see the display flash (not necessarily), but then the TV clicks back into standby mode. If so there is a component failure.
will need diagnosis by a repair shop. Too many different components it could be for me to guess. but
the common repair kit containes1 fuse (F302), 1 diode (D304), the power resistors (R927 and R929 for the board revisions with these two resistors) and the IC301 voltage regulator IC.
Feb 21, 2018 | LG 50PJ350 50 in HD-Ready TV
Rear protector tv stuck on standby and won't turn
Possible there is fault in the processor section of the main board. You will need to check the main rail of 5 volt to the processor and allied section to start with the probe. If absent the 5 volt regulator must be checked. If present the processor and in many cases the board is a suspect as component level work might be difficult unless equipped.
Jan 07, 2012 | Panasonic Televison & Video
My 40' vivo tv has turned off and won't turn back on but the red stand by light is on??
If the standby light is on and it does not respond, it is most likely to be a problem with the power supply . First try this, unplug and leave the set like that for a few hours. Then plug it back in to see if the tv attempts to turn on when you try to power it up. See if you hear a "click" even if it goes back to standby. Let me know what you found so that I can help you test the power supply board to confirm, if necessary.
Aug 18, 2011 | Televison & Video
Emerson LC320EM9 32 in. LCD HDTV Logo
1,504 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
