Stuck behind drum
I too have something stuck in the lining of the drum. i have a front loader electrolux only 2 years old and wonder if i can some how get it out without getting a repair person to come over and fix it.
    Sergeant:
    Champion:
  • 353 Answers
Take the hose off the drum at bottom of machine and fish it out with apiece of wire
Posted on Jun 30, 2009
  • 3 more comments
  • hotpoint jon Jun 30, 2009
    take the hose off the drum at bottom of machine and fish it out with apiece of wire
Belt snapped ..motor shaft turns freely
could be bearings or a brake for the drum energized
Call in a technician and get a repair quote
Jan 10, 2016 | Electrolux Washing Machines
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
Jan 21, 2013 | Electrolux Washing Machines
Screw stuck behind drum making it not rotate
You will need to remove the drum and assembly, please check on this link for tips: Drum removal
Jul 07, 2012 | Washing Machines
I have a broken bra wire stuck behind drum of LG turbo drum washing machine, how do I get the drum out??
You don't say if it's a front or top loader. I managed to get one out with a strong magnet inside the drum just moving it about until it appeared near one of the holes in the drum without taking the machine apart. But it was a front loader and is probably easier than a top loader.
Jan 26, 2012 | Washing Machines
The drum is not going round and just before it stuck there was a sound of clanging inside the machine
Sorry but you do not say which make and model, just that it is a front loader. If the drum is jammed, there must be something stuck inside which may mean a call-out.
If the drum will move round by hand it could be that the belt has snapped or the motor is malfunctioning.
Hoping for the latter I am answering with my general guidance notes ;-0)
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed if it has not snapped already. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished.
Hope this is your problem solved.
Good luck,
John C
Feb 22, 2011 | Washing Machines
Bra wire stuck between drum and casing, how can I remove?
our is a Bosch nexxt front loader, we removed a heating element. Were able to get access the area of drum unit where the wire was.
Jun 19, 2010 | Electrolux Washing Machines
I have the same exact problem! Machine eating change & clanking?
try taking the heater element out and using aold coat hanger fish for the coin
Sep 20, 2009 | Maytag EPIC MFW9700S Front Load Washer
Front loader washing machine - noisy spin cycle
A service engineer told me he thought there was a piece of wire caught behind drum and to see if it worked its way out. It hasn't because I don't think he's right. On spin the noise is sometimes so loud it sounds like the bearings have gone. Today I removed the fluff filter and discovered what appears to be shreaded grey plastic. If I can get a copy of the machine spec I might be able to discover where this has come from. Sorry this is not a solution. But as your symptoms are so similar check your filter and see if its full of shreaded plastic.
Sep 23, 2007 | Electrolux EW1000i Front Load Washer
Electrolux front end loader
How Old is the machine: Is it within the 5 year major parts cover? If so the drum bearings are covered.
Aug 26, 2007 | Electrolux EW1000i Front Load Washer
Washer wont spin
sounds like the motor or clutch unit could be the problem I would for sure call in the warrente shop to fix it as if its the motor thats expensive!! good luck
Apr 29, 2006 | LG WM-1832C Front Load Washer
Washing Machines Logo
275 people viewed this question
Top Washing Machines Experts
