Question about Kicker Solo-Baric L7 S12L7 Car Subwoofer
My spider in my l7 kicker is riped how do i fix it
Ya i fixed it mi self i ant payin for this **** it retarded
Posted on Jun 30, 2009
My kicker sub seems to rattle alot inside the box is it blown?
Most subs when they "blow" usually seperate from the spider, which gives you a rattling noise. if you have a port in the box, it could be possible that the inside tube has come out. the easiest way to tell is to pull the sub out of the box and see if anything is loose inside there. if there isnt anything then smell the sub where the spider is. if it smells like burnt plastic/metal then yes it is blown.
I hope this has helped you and please dont forget to rate my solution for you.
cheers
Jan 14, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need every thing for a 8" kicker but the magnet and basket
Kicker don't sell parts as they want you to buy new drivers but you can find replacement spiders and coils at speakerex.com and maybe post to your local craigslist for a blown sub of the same type to get everything else.
Good luck
Nov 24, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Only one voice coil is working on my L7 10" sub? All connections look good. 2 2ohm subs wired to 2ohms with a Kicker zx1000.1 mono amp. why?
If the tinsil wires all look good then chances are you broke a lead in the coil, the only way I know of to fix this is to order new voice coils and a new spider and replace them..
There are places on the web to order parts, you just need to take good measurments of the parts and relay them to the stores.
Nov 19, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Hi there I have a problem with my kickers. Subwoofer l7 15" is blow,I was wondering if there is a repair kit avaible for it or not?
The only Kicker woofer that has a replacement cone/assembly is the SoloX woofers. All of those have what Kicker calls it's SPARE which is a field replacement assembly. They're designed for SPL competitions.
Nov 05, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Need new spider
go to Kicker.com...they should have what you need.
Jul 25, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Solo baric l7 WOOFER... CAN I REPLACE THE VOICE COILS?
well you can bring it into the place you bought it.. or a place where they sell kicker brand subs.. and ask them for a fix..
they'll either order you another one or.. they'll send it to be fixed.. depends on what it is(note) kicker L7 is made to be taken apart and fixed
Jul 06, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Voice coils
Hello. I do speaker reconing and amp rebuilds for a living and the L7's often suffer from tinsel leed wire breakage which can cause "poping" and "screaching" noises in the sub in various cone positions. You need to remove the sub and push straight down on the cone repeatly and determine if you can feel or hear crunching noises to make sure the voice coil and/or spider are not damaged. A faulty leed wire can usually be identified by a dark spot or obvious breakage. All of the L5 and L7 models can be successfully repaired as long as they are the older models that have a center cap in the cone. The newer capless models will have to have an upper brace cap glued to all of the cone's fingers and will have a rather ugly appearance. Leed wire overhauls usually run around $30.00 for the older models. Voice coil and spider overhauls run around $90.00.
Dec 12, 2007 | Kicker 02S10L74 Car Subwoofer
Kicker zx750.1& two 15"kicker solo L7 2ohm
if the amp could handle 1ohm paralell would work if not they wire in series
Apr 08, 2007 | Kicker (ZX750.1) Car Audio Amplifier
Kicker Solo-Baric L7 S12L7 Car Subwoofer Logo
399 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
