Haier XQJ50-31 Top Load Washer Logo
Posted on Jun 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drum will not spin
Will not spin
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 235 Answers
  • Posted on Jun 30, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
235
Questions
Helped
70390
Points
680
Belt is probably off the pulley or broken.
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
1helpful
Dryer will only spin with small load
You need to replace the belt that will solve all your problems.
Oct 17, 2012 • Dryers
1helpful
Have a Kenmore 20902 top loading washer. Does aggitate in wash cycle, but wont spin in rinse. With drum empty, it will spin. Removed cloths, rung dry by hand and returned to drum. Still would not spin, but...
Your drum is in a sense sitting on a barring , it sounds like your barring is going out. Works with no weight, and if helping as you said. Normally means barring is worn out and can not handle any weight.
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
2helpful
2answers
WM1832CW has stopped spinning. Tries to spin but
If the drum is loose it probably means that the bearings at the rear.....OR...The arms that connect the drum to the pulley shaft have broken.....Major job....Sorry.....Nomess
2helpful
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
2helpful
Dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Sep 03, 2009 • Dryers
Top Haier Washing Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
