Question about Maytag Performa PAV2200
Spin Cycle I have a Maytag PAVT244AWW. I started a wash and it filled up and then started to agitate then I noticed it stopped and it was smoking. It is only about 2.5 yrs. old. I emptied it and then put it in the spin cycle to see if it would. It did, but when I opened the lid it stopped immediately instead of slowing down and then stopping. It also made a breaking noise when it stopped abruptly. What is up? Your advice would be greatly appreciated. Thanks,Charlie
    Scholar:
  • 196 Answers
The tub will come to a very quick stop when there is nothing in the machine. The breaking noise is the nylon break pads in the break assembly. This noise can be stopped by putting talcum powder into the break assembly. As far as the machine stopping and smoking ? I suspect a stuck/partially stuck break causing the belt to slip and heat up.
Posted on Jan 08, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
Washing machine starts agitating before fill
Pressure switch stuck you can pop the hose off the switch and blow thru hose it may reset and fill correctly before agitation will eventually stick again.
Jan 12, 2014 | Maytag Washing Machines
Maytag 9700 fills then stops, won't agitate or spin
What is the model number list on the machine? Look on the top of the console.
Oct 13, 2012 | Maytag Washing Machines
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer will not agitate
A Maytag A412 is well over 20 years old....
Best guess is a corroded upper drive shaft, the one that the agitator is mounted on. Certainly it can be called a transmission problem.
Jun 28, 2017 | Maytag Washing Machines
Maytag washer model PAVT244AWW will not agitate during wash cycl
When the machine drains etc the gearbox locks up and the whole unit drum box and all spins when washing the gearbox innerds move the otherway so to speak and this cuasees a washing action this sounds as if the input shaft may need replaceing but it is usually better to replace the gearbox depends on finances but to be sure get a technition in to check and quote you first this is not something you can do if you have not done it before
Jan 25, 2009 | Maytag PYE2300AY Electric Dryer
Maytag washer will not agitate. model pavt244aww
TURN THE PULLEY ON THE BOTTOM. ONE DIRECTION WILL CAUSE THE PULLEY TO TRAVEL UP AND RELEASE THE BRAKE, CAUSING THE TUB TO SPIN. TURN IT THE OTHER WAY AND THAT SHOULD BE YOUR AGITATION. YOU SHOULD HEAR THE TRANSMISSION CLUNK AS THE GEARING CHANGES DIRECTION TO GE THE AGITATION ARC. IF NO NOISE IS HEARD, YOU HAVE AN INTERNAL PROBLEM WITH THE TRANSMISSION.
Washer model PAVT244AWW agitation noise
Sounds like the motor is going bad. It will only get louder before it finally stops. There is a device that assists the agitation motion that may be bad or is going bad.
Dec 01, 2008 | Maytag PYE2300AY Electric Dryer
Washing Machines Logo
316 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
