Question about RCA P52926 52" Rear Projection Television
Blank screen i was watching tv tonight then just like that the screen went black i had sound just no picture... i turn to offair and nothing still so i just walked away from it to call a tech but no answer then about 20 mins of cusing the picture can back kindof then after 5 mins of lines i got a normal picture my tv is a 56 rca i got about 6 years ago and its a rear projection i just wanna know what you might think is wrong with it and the cost to debate on junkin it.. thanks
    An expert whose answer gotĀ voted for 100 times.
  • 317 Answers
Re: blank screen - RCA P52926 52" Rear Projection Television Projection Televisions
For what
Posted on Jun 01, 2008
0 characters
3 Points
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ... > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
May 8, 2014 - Uploaded by
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Projection Televisions
I have Samsung 46" rear projector TV the TV just went blank
? 3:16
TV Repair Help for a TV With a Black No Image on the Screen ... the show I'm watching and then it turns ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
Mar 4, 2014 - Uploaded by
i have SAMSUNG led tv with NO picture and there is back light and sound OK, ... Apparently the TV was on ...
Dec 15, 2015 | Samsung Projection Televisions
My screen went blank but the sound works fine. We were watching TV when the screen went out. The sound stayed on. We still get sound but no picture. Is this worth fixing? If so what is the best way to go...
all in one day my screen started by showing a u look at top and bottom. all three colors kind of separated from each other and therefore made shadows on all the writing and double and triple vision on people and images. then it drawed in from sides and showed some black. then it popped in the back and no picture. the sound then came back on with no picture. so i shut it off and unplugged it. what do i have to get to fix this? thank you, Robert Hopkins
Jan 01, 2011 | Akai PT5598HD 55" Rear Projection...
Hitachi 43FDX20B, watching tv, screen went blank, no picture, no sound turn off then back on power light on but the same nothing
The TV computer may have detected an error. See if the problem persist after unplugging the device overnight to reset it. If it does not, the issue may be with the board or its power supply circuit. Probably loose soldering or leaking capacitors.
Jul 24, 2009 | Hitachi 43FDX20B 43" Rear Projection...
Toshiba projection tv
Sounds like it blew an "Internal Fuse"
if you want to fix it..simply open rear of TV and look for the fuse.
here is link for a manual if you do not have one.
Feb 05, 2009 | Toshiba 43H70 43" Rear Projection...
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Only picture in picture works
Your pip module has went south.The capicitators on the board have leaked and ruined the board.Agood tv repair man can bypass the module to get you a full screen picture again.The only problem is you will no longer have pip ability.
Mar 07, 2008 | Sony KP-48S75 48" Rear Projection...
Sound stays on & picture goes to blank screen
I do not see any reference on this problem and I even checked with Sony. If you are on a cable box, I suspect that is the problem.
Oct 25, 2007 | Sony KP-43T70 43" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
111 people viewed this question
Top RCA Projection Televisions Experts
The Wyzzyrd
D. E. Hev
Ron Dufek
Ron Dufek
Are you a RCA Projection Television Expert? Answer questions, earn points and help others
