Question about Yamaha Full-Size Keyboard
My Yamaha PSR-260 Lights up But can't hear a thing
Yamaha PSR-260 when I plug it in it lights up, but nothing comes out of the speakers on it. when you push the keys words come up, everything else appears to work. but sound wont come out even if volume is all the way up, What am I doing Wrong?
Any one know how
Posted on Apr 26, 2011
Why there is no sound when i turn on the keybord?Display is ok.
Check with a small speaker or amp plugged in the back. If you can hear it then the jack in the back is probably not making contact. If no sound comes out there then the Audio Amp or it's circuity in the organ is more than likely to need repair.
May 22, 2014 | Yamaha PSR-E423 Portable Keyboard
Repairing Yamaha psr-12
If the power adapter is not the original adappter- check to make sure the polarity is correct- it should be marked on the keyboard near the adapter socket, and also on the adapter itself.
The keyboard should have an internal fuse- check that. Then with keyboard open, if the fuse is okay, trace the power flow from the power pack and look for broken wires, bad solder connections, stressed components like bulging capacitors, etc. It may have a burned out zener diode in the power supply regulator portion of the main circuit.
Mar 29, 2012 | Yamaha PSR-E223 keyboard
I would like to know which transformer I can use with the Yamaha PSR 260? How many AMP's? Volts I know are 10-12.
You should be using the Yamaha PA-3B adapter. The unit draws 9 watts... so at 10 volts a 1 amp adapter would be great. Make sure the polarity is correct.
Sep 07, 2011 | Yamaha PSR-295MS Portable 61-Key...
I HAVE A Yamaha PSR 260. About 8 years old. Recently it became defective.: Only the display lights up . No sound. No response to any button. When volume control is turned, I can hear the faint rustle on...
This MAY be due to a key contact or button that is STUCK "on".
Often this will freeze the controller.
Make sure power adapter is the correct one... underpowered or incorrect ones cause trouble.
Mar 20, 2010 | Yamaha Music
I have Yamaha psr 260 and I am connect on 24V, and now speakers dont work. What am I doing?
I believe that is the wrong VOLTAGE !!!
The PSR takes a 12 volt, 1 amp or more DC power supply with positive on the pin.
If you have connected 24 volts either AC or DC of either polarity you have likely caused internal damage. Try a 12 volt DC supply and if it doesn't work, it needs to go to a repair facility.
ALWAYS check the voltage and the polarity on ANY of the devices using the power adapters BEFORE connecting the adapter..
Feb 18, 2010 | Yamaha Music
Yamaha PSR-27; NO SOUND
If it is very old, check if the volume control could be contaminated. Make sure a voice is selected via the buttons.
Do try the headphones before anything further.
Jan 20, 2010 | Yamaha Music
Yamaha musical keyboard makes mono tone when turned on?
Check that you have the exact power adapter for the unit.
Dec 03, 2009 | Music
No volume at all out of speakers PSR-E203. Plugged in to AC supply. Yamaha Portatone PSR-E203 YPT-200
Make sure you use correct power supply.
Try headphones. If they work, then the switch on the headphone jack that disconnects the speakers may not be working properly and not connecting the speakers.
Oct 13, 2009 | Yamaha Music
Psr-60 serial no 008012
Yamaha PSR 60. Power light comes on but no sound from any of the keys or anything else. Can anyone advise
Jul 28, 2009 | Yamaha Portable Keyboard
Yamaha psr-240 lights up but no sound.. no sound from head phones either. Seems to be working with exception of sound out..
try placing your ear on the speakers, adjust the volume control up and down several times, you should hear a humming sound that goes up and down. if not problem with the stage before the amplifier, that is the sound processor. if you dont hear the hum. problem with the amplifier and speakers, including the sound ports or jack. dissassemble the unit. look for loose connections from speakers to amplifier.
Jul 14, 2009 | Yamaha Portable Keyboard with 61...
Yamaha Full-Size Keyboard Logo
539 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
