Question about Dometic Rooftop RV Air Conditioner
My dur therm air conditioner fan turns on but compresor does not
When I first started it up the fan came on and then the compresor after turning the colder dial. The compresor shut off in about a minute and after a little while it came back on again but once again shut off. And has not come back on since. I have tried warming the sensor in the vent to get it to come on but still nothing. The dial is set to the coldest position. When the compresor did come on it was blowing cold air, I need it to blow cold air all the time and would just as soon bypass the sensor if this is the problem.
I got a new control box for my Duo therm travel trailer A c unit . when I removed the old unit and started to replace it with the new unit I found that the new unit came with a new thermostat which I replaced > The thermostat came with a detailed wiring digram and it was easy to install. When I started to wire the new box i discovered there is no wiring digram for the new control box. My question is where can I get a wiring digram that will help me to wire in the new box witout making a mistake and hurting the new unit?
Posted on Jun 30, 2009
    Problem Solver:
  • 5 Answers
It could be the (LP) low pressure switch which would shut the unit down
Duro therm , penguin 2 1988 model
ADDING FREON IS A LITTLE MORE COMPLEX AND BEST LEFT TO A PRO, YOU CAN MAKE SURE THE FAN IS OILED AND THAT THE FINS ARE CLEAN, TAKE NOTE IF YOU SEE A OILY SPOT ON THE UNIT THIS MAY BE THE SIGN OF A FREON LEAK ,, IT MIGHT BE WELDED AND RECHARGED .. THATS MORE BETTER THAN BUYING A NEW UNIT CUZ THESE AINT CHEAP ! JAY THE POOL PUMP GUY IN LONGWOOD FL
Feb 02, 2012 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
Fan running but dont hear comp. turning on
First check for burned wires in all the componnents in the condensing unit ,also the compresor terminals ,if they're all ok and if you know how and have a tester check the compresor if is not burned or grounded. After that you can replace the capacitor (is no more than $20) and if still won't start it means the compresor is either burned or stock.You can also try to put a start booster in parallel with the capacitor ,sometimes it helps it to start.
Aug 11, 2009 | Goodman CKL60AR60 Air Conditioner
Ruud 10 compressor not working
First make sure there's power to the unit outside , if yes set the theermostat on cold ,auto and to the lowest degrees ,then look the outside unit contactor, it should be pulled in (sometimes it takes to 5 minutes beacause a time delay) , if not the problem is in the thermostat , but if yes and there's power on the other side of the contactor ,either the compresor running capacitor is bad or the compresor itself went bad .Try replacing the capacitor first (the cheaper option) and adding a startting booster in paralel with the capacitor ,if still the compresor doesn't start you nedd to replaced it.All this counting that the fan in the outside unit works ,if doesn't replaced it.
Aug 05, 2009 | Ruud Matching Split Air Conditioner
Unit turns on but condensor dont kick in
Need to pull the cover off and see if the compressor is comming on.If not have someone with electical experience check the contacter.Sometimes bugs will get under the contacts durring wenter.If it is running the freon is low
Jun 27, 2009 | Dometic Rooftop RV Air Conditioner
Compresor starts but fan just buzzes.
No , is their power to the motor? could be bad motor or capacitor?
Jun 16, 2009 | Coleman Mach III Air Conditioner
Dou Therm Brisk Air not running
Turn the ac off go up top the coach and remove the cover. Look for fan blockage, Wasp, mud dauber etc. Caution if it is wasps they will chase you off the end of your coach. Take some spray with you. If there is no blockage the fan motor is toast.
Thanks for using Fixya
Jerry
Mar 27, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
363 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
