Question about Kenmore Washing Machines
Water does not drain out - Kenmore Washing Machines
  • 15,935 Answers
If you experience a problem where the washer does not drain and the drain pump does not run at all, here’s the information you need to replace the drain pump:
Symptom: PUMP IS NOT RUNNING, NOT DRAINING AT ALL.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. Sometimes objects get caught in the pump impeller and stop it from running. We’re going to assume that you have already done this and that the pump no longer runs. It is strongly recommended that you remove all residual water from the wash tub & drain line at this point or you will have about a gallon or so inside your washer and on the floor to clean up.
5. HINT: Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
7. Locate the electrical connection to the pump and disconnect.
8. Now locate the two drain lines and remove them. The hose clamps can be released by squeezing with a pair of pliers. NOTE: I would not recommend removing the hose from the bottom of the wash tub unless you really have to. This one can be difficult at times to get back on.
9. Remove the torx type screw at the front center of the pump and it should slide right out of the mounting grooves on the bottom of the washer case.
10. Your new pump comes with several adapters to place on the feet of the pump in order for it to properly fit your washer. These are rubber bushings that help get rid of vibration and noise. If you become confused, there should be installation instructions that come with your new pump. You can also look at the pump you just removed to see how the bushings are mounted.
11. Reinstall the drain lines to the pump. HINT: It is much easier to do this with the pump still OUT, rather than installing it. When you squeeze the clamps to open them up, make sure you slide the clamp completely over the hose AND the inlet/outlet tubes on the pump housing in order to get a good seal.
12. Reinstall pump by sliding the feet of the pump into the mounting grooves on the bottom of the washer case. Tighten the center screw and reattach the electrical connection.
13. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
14. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
15. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump is supposed to energize and begin to drain.
16. If the pump works normal and there are no leaks detected, reinstall panel and tighten screws.
CAUTION: Use care when reaching inside the washer case not to damage the small wire harness that runs along the front of the machine.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
NOTE: My initial symptoms describe a drain pump that is NOT running. It is actually possible for the drain pump to be running and STILL not drain. If the pump impeller becomes damaged, or if the motor shaft is stripped, the pump will run, but will not drain properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
How do I drain the water tank
Anon, Make sure gas or breaker(power) is turned off to the Heater so it will not come on during draining,connect a hose onto bottom valve of water heater, run hose to a floor drain and insert, turn your water main off so as not to fill tank while draining, open water heater drain valve, water will then drain from attached hose into floor drain until empty. For water to run faster you may open a near by hot water tap, this will allow air into tank as you drain it, do not forget to turn this tap off before refilling tank. You then can turn main back on for a bit if you would like to do a flush of sediment from the bottom of tank.
See links below for more instruction and video.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Drain Water Heater Today Homeowner
How to drain water heater
http://www.bobvila.com/articles/how-to-drain-a-water-heater/#.VxqJ6NQrJxA
Apr 22, 2016 | Water Water Heaters
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
I just noticed that my hot water heater that is 6 years old is dripping very slowly from the bottom faucet, how can i stop this leak. thank you.
If you mean the drain valve, then buy garden hose cap at home center.
Cap will have rubber washer that seals tank.
If drain valve is plastic, the cap may not thread on without sanding down end of plastic drain valve.
Otherwise replace drain valve, which is simple if drain valve is brass, but can be difficult if drain valve is plastic.
Turn off power to water heater: Electric: turn off circuit breaker. Gas: turn knob to pilot.
Turn off water, open bathtub spigot on Hot side, drain water heater, remove drain valve with wrench.
If plastic drain valve breaks while being removed, then 'gently' break out broken part using hammer and big screwdriver.
Buy new drain valve at box store in water heater department.
Put teflon tape on new drain valve threads.
http://waterheatertimer.org/Water-heater-is-leaking.html
http://waterheatertimer.org/Water-heater-will-not-drain.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Not washing dishes
check the water make sure the water is correct. fill water drain water and circulation water.
fill water comes from under sink, drain water from drain pump and drain hose ,circulation pump controls the water washing. let me know if this helps.
Mar 06, 2010 | Dishwashers
How do you remove the water pump on a 2006 monte carlo
  1. Drain the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  5. Remove the water pump bolts.
  6. Remove the water pump and gasket.
  7. Clean the water pump mating surfaces
    1. Position a NEW water pump gasket and the water pump to the engine front cover. Notice: Refer to Fastener Notice.
    2. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolts.
  2. Install the drive belt.
  3. Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.) .
  4. Fill the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  5. Inspect for leaks.
Hope this helps
Oct 01, 2009 | 2006 Chevrolet Monte Carlo
Water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
Jun 07, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
