Question about Garmin Forerunner 205 GPS Receiver
No satellite signal pick up
Hi, I have Garmin Forerunner 205, which I got about 3 years ago. It used to pick up the satellite signal at my house without any problem. Now, it won't do so -- it'll keep spooling indicating it is but it never picks up, even after 2 hours. It never gets past about 25% of the signal bar. I've moved the device around to various locations and it's the same result. Would a new battery fix the results? It turns on and off just fine.
    Brigadier General:
  • 4,090 Answers
Yes ! 3 years is at the end of the expected lifespan of the battery
Posted on Jun 30, 2009
How to remove battery from garmin 205 ?
they are fixed in you have to take the hole thing to bits
Jul 27, 2014 | Garmin nuvi 205W GPS Receiver
Garmin 295 forerunner will not turn on
Did you mean the Forerunner 205?
It is most likely that the battery has died in the unit or there may be a problem with the battery charger.
The internal battery in the Forerunner 205 is not user replaceable and the unit would need to go back to a Garmin repair for replacement.
Please call Garmin Tech Support for assistance.
1-800-800-1020
Feb 29, 2012 | Garmin Forerunner 205
I reinstalled the driver of my garmin forerunner 205 but it is still not recognized by my computer. it has been working for over a year but now I do not get any connection and the device is not recognized...
When you connect the unit to the cradle is there any reaction from the unit? I would try using a different USB port and cord first if this dosent fix your problem the next step would be to obtain a new cradle for your unit. They can be purchased here http://www.gpscity.ca/garmin-forerunner-205-305-charging-cradle.html.
Hope this helps!
Feb 25, 2011 | Garmin Forerunner 205 GPS Receiver
I have had my garmin forerunner 205 since end of May 2010. It recently started taking longer than normal to find satelites. On my last run it came up as saying battery low when I had only just charged and...
You need to contact Garmin and have them replace or repair the watch. If the watch is less than a year old, it will be under warranty. Older than a year it may be a repair or replace only situation, Garmin will have to determine that. It is not unusual for the forerunner series to have rechargeable batteries that die off.
Jan 04, 2011 | Garmin Forerunner 205 Gps Training Watch
How do i change the battery in a forerunner 205
First, here's the link for the owners manual for your Forerunner 205 GPS Receiver:
http://www8.garmin.com/manuals/984_OwnersManual.pdf
The only battery replacement instructions are on page 65 of the owners manual:
Feb 07, 2010 | Garmin Forerunner 205 GPS Receiver
Forerunner 205 will not locate satillates
Go to garmins site. Not sure if they have the download for this or not but generally some of the GPS's loose satellite reception software and you can download the fix for this for free. If you have questions they are great to deal with and will walk you through it. I have downloaded this fix for several GPS's but you will have to check to see if they have it for your particular GPS. Here are their numbers for contacting them.
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Sep 12, 2009 | Garmin Forerunner 205 GPS Receiver
Won't locate satellites each time you turn it on.
The GPS does not have a line of sight to the satellites. Relative satellite position may vary somewhat through the year as the Earth wobbles on it axis. Reposition the GPS in your vehicle.
Sep 16, 2017 | Garmin Forerunner 205 Gps Running Watch
Garmin Forerunner 205 Battery won't charge. A few
Hey everyone. Just called Garmin and got it fixed. Sometimes the forerunner goes into power saver mode and needs to be reset
1. Hook up the usb cable and docking station to the computer.
2. Next, hook up your forerunner to the Docking station - It should pop up saying battery charging in progress
3. Leave it all hooked up and Hold the Mode and Lap/Reset Button together for 15 seconds - screen should go blank.
4. Let both go - should pop back up saying battery charging in progress.
5. Let Charge 20 minutes and it should be good to go.
Hope this helps!!!
Kenny
Feb 20, 2009 | Garmin Forerunner 205 GPS Receiver
Garmin 205
I called Garmin support about this issue so if it happens to you, here's what you do.
Go to the main menu, find your way to the About screen and see what version of the software you have. Mine was 0.00, which means i somehow deleted the software. you then hook the garmin up to the computer and run the webupdater.
I didn't think it was a software issue because i couldn't locate satellites but apparently the chip controls the satellites so I was obviously very wrong there. at this point, the time was still wrong on it so we did a hard reboot, and now it's working like a charm.
Sep 17, 2008 | Garmin Forerunner 205 GPS Receiver
Garmin Forerunner 205 GPS Receiver Logo
1,014 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
