My indesit widl 126 keeps filling with water and delay timer and on off led constantly flashing also the dryer doesnt heat up anyone know what the problem is
  • siannbootz Jun 30, 2009
    i stuck jet wash down front filter and waste pipe(realise now wasnt the cleverest thing to do) all stuff come out coins etc now the delay timer led and door lock led are constantly flashing and machine keeps filling with water do you think this could of caused the problem and would it of affected the air pressure pipe in /out let valves and if so where are they located ?any tips/ advice would be appreciated thanks
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
I have an Indesit Washer/dryer (WIDL 126 S), and it is dot draining the water. I set in on drain or dry and nothing happens, it just fills with more water.
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump needs replaced.
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Washing Machines
Indesit washer/dryer widl 126s
Hi gmarf....to reset your machine to cancel those symptoms, Unplug your machine from the Wall Outlet for a minimum of 1 minute. Upon restoring power, it should be reset and ready-to-go.....If you have any further questions or issues please update your post....good luck my friend
Aug 12, 2007 | Indesit W 123 Front Load Washer
Indesit WIDL 1265 All LED's are flashing regardless of switching power on and off. Managed on last wash to power on and off and have a wash sucessfully. Now it's just constant flashing. ??? Anyone ??
Unplug for 40 minutes to attempt a reset of the ECU - otherwise you must replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Indesit W 123 Front Load Washer
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Indesit WIDL 126 washer/dryer
look at http://www.indesit.co.uk/indesit/productsheet.do?productId=30538UK
Jul 06, 2008 | Computers & Internet
WIDL 126 S WASHER DRYER
what u can check is the outlet hose does it go down a plastic pipe if so pull it up slightly until it stops a simple mistake if its gone down slightly too much what happens is if its low down the pump kicks in as it thinks the pipe is lower then the washer to drain it try it if i isnt this then it will more then likely be a faulty timer which u will have to replace m8 let me know how it goes m8
Dec 13, 2007 | Indesit WA 125 Front Load Washer
Washing Machines Logo
259 people viewed this question
Top Washing Machines Experts
